Brainchild Customs Posted January 10, 2013 Share Posted January 10, 2013 ^They probably already have huge turbos, I assume most are diesel. My chevy pickup came from the factory with a GT35 on it! Exhaust intake and chip was about +150whp/+300ft/lbs Accessport for UPS trucks=profit? Link to comment Share on other sites More sharing options...
Blizzard Posted January 10, 2013 Share Posted January 10, 2013 ^They probably already have huge turbos, I assume most are diesel. My chevy pickup came from the factory with a GT35 on it! Exhaust intake and chip was about +150whp/+300ft/lbs Accessport for UPS trucks=profit? Diesel powaaaah Link to comment Share on other sites More sharing options...
acumenhokie Posted January 10, 2013 Author Share Posted January 10, 2013 Do you suppose there are any mods available for the brown trucks? I wonder if they do any suspension mods or adjust the alignment since they only make right turns. Link to comment Share on other sites More sharing options...
acumenhokie Posted January 25, 2013 Author Share Posted January 25, 2013 New plugs showed up this week. BPV should arrive tomorrow. Link to comment Share on other sites More sharing options...
Blizzard Posted January 25, 2013 Share Posted January 25, 2013 What did you buy for a valve? Which plugs? Link to comment Share on other sites More sharing options...
acumenhokie Posted January 26, 2013 Author Share Posted January 26, 2013 What did you buy for a valve? Which plugs? NGK 2309 (LFR7AIX) Plugs and TurboSmart 34mm BPV Link to comment Share on other sites More sharing options...
Blizzard Posted January 27, 2013 Share Posted January 27, 2013 NGK 2309 (LFR7AIX) Plugs and TurboSmart 34mm BPV The 50/50 or the diverter valve? Link to comment Share on other sites More sharing options...
acumenhokie Posted January 27, 2013 Author Share Posted January 27, 2013 The 50/50 or the diverter valve? 50/50. http://www.ebay.com/itm/TURBOSMART-KOMPACT-DUAL-PORT-BLOW-OFF-VALVE-34MM-TS-0203-1023-/170707539312 Link to comment Share on other sites More sharing options...
Blizzard Posted January 27, 2013 Share Posted January 27, 2013 50/50. http://www.ebay.com/itm/TURBOSMART-KOMPACT-DUAL-PORT-BLOW-OFF-VALVE-34MM-TS-0203-1023-/170707539312 While the 50/50 is a cool concept I still don't know if it's a good idea with a MAF. You are still going to screw with the fueling with 50% of the air being ejected from the system. You are planning to go visit a protuner after you install it right? You aren't SD tuning it are you? I think I may buy the 34mm diverter valve version in the spring time. TS-0203-1223 Link to comment Share on other sites More sharing options...
Rutchard Posted January 27, 2013 Share Posted January 27, 2013 That Turbosmart can do full recirc if he wants. Link to comment Share on other sites More sharing options...
BigBopper Posted January 27, 2013 Share Posted January 27, 2013 I installed mine as a full recirc as well. A blank off port plate is included with the BOV. As Bliz stated, once the volume of air is measured by the Mass Air Flow Sensor in the intake, the ECU adjusts for the proper fuel mixture. If you dump off some of that air using a BOV, now you have a momentary lean condition which can cause backfires, etc... If the same BOV is configured for full recirc as a BPV, you don't have that issue since all the air has been accounted for in the fuel trims, as it passes thru the engine. Also, due to the location and orientation of the BPV on the 5th Gen LGT, if you were to run this BOV as a 50/50, the open port would be facing upward, exposing the slide piston to the elements ... (i.e., maintenance issues). Since a 50/50 BOV setup does not provide any performance gains, it's a matter of how badly you want to hear the air vent, and willingness to deal with the associated problems that come with it. Here's some good info related to the use of BOV's and BPV's: http://legacygt.com/forums/showthread.php/technical-info-bov-bpv-set-up-and-operation-150687.html Link to comment Share on other sites More sharing options...
Blizzard Posted January 27, 2013 Share Posted January 27, 2013 That Turbosmart can do full recirc if he wants. Oh I know, just seems pointless to spend $70 extra dollars if you just plan to run in resirc unless someone plans to go SD like you. I installed mine as a full recirc as well. A blank off port plate is included with the BOV. As Bliz stated, once the volume of air is measured by the Mass Air Flow Sensor in the intake, the ECU adjusts for the proper fuel mixture. If you dump off some of that air using a BOV, now you have a momentary lean condition which can cause backfires, etc... If the same BOV is configured for full recirc as a BPV, you don't have that issue since all the air has been accounted for in the fuel trims, as it passes thru the engine. Also, due to the location and orientation of the BPV on the 5th Gen LGT, if you were to run this BOV as a 50/50, the open port would be facing upward, exposing the slide piston to the elements ... (i.e., maintenance issues). Since a 50/50 BOV setup does not provide any performance gains, it's a matter of how badly you want to hear the air vent, and willingness to deal with the associated problems that come with it. Here's some good info related to the use of BOV's and BPV's: http://legacygt.com/forums/showthread.php/technical-info-bov-bpv-set-up-and-operation-150687.html Yeah this is what I was getting at. Link to comment Share on other sites More sharing options...
acumenhokie Posted January 27, 2013 Author Share Posted January 27, 2013 Oh I know, just seems pointless to spend $70 extra dollars if you just plan to run in resirc unless someone plans to go SD like you. I'm planning to get tuned at IAG (who will be installing this, the turbo, injectors, etc. all at the same time). I want to give the turner as many parameters to play with as possible in hopes of getting maximum POWA! Link to comment Share on other sites More sharing options...
Rutchard Posted January 27, 2013 Share Posted January 27, 2013 It's nice to have the option to go either way if you want to in the future without buying another valve. I'd probably run in in full recirc, but remove the plug at autox or the drag strip because racecar. Link to comment Share on other sites More sharing options...
minuccims Posted January 27, 2013 Share Posted January 27, 2013 NGK 2309 (LFR7AIX) Plugs and TurboSmart 34mm BPV So the recommended plug is Iridium IX LFR6AIX-11 Stock num 6619 Gap .032 So looking at some info tying to learn..... And so the 2309s are one grade colder. 5th gen stock turbo pushes >75hp down low but is pathetic above 4k. TMIC adds about 20HP. This does not seem to warrant colder plugs. Say above 75-100 hp from stock is a general guide to go one step cooler. What are to guidelines to go to colder plugs as a precautionary measure to keep combustion chamber temps within range, as to not pull timing to prevent detination and engine failure? Also are the colder gapped any different than .032? Thanks!! Link to comment Share on other sites More sharing options...
acumenhokie Posted January 27, 2013 Author Share Posted January 27, 2013 (edited) So the recommended plug is Iridium IX LFR6AIX-11 Stock num 6619 Gap .032 I just asked Bopper what he was running and bought the same ones. These will go in at the same time as the 20G. Here's what I've ordered so far or have in hand: RacerX TMIC NGK Plugs Crawford AOS ID 1000cc Injectors DW300 Turbosmart 34mm BOV Silicone Lines/Stainless Clamps ebay front lip (worth at least 5hp) To Do: BNR 20G (Calling on Monday) Order EBC Order + Fab intake Figure out Turbo Blanket/Heat Wrap Finalize who is going to tune me Get everything installed Other suggestions? I've decided to get everything running smooth on pump gas and see what explodes before deciding on an e85 tune. Edited January 27, 2013 by acumenhokie Link to comment Share on other sites More sharing options...
islandborn Posted January 28, 2013 Share Posted January 28, 2013 Check on the turbo blanket.... When I asked - there is no need for it (turbo location) and install would be next to impossible as the tightness of the fit of the turbo itself. Link to comment Share on other sites More sharing options...
acumenhokie Posted January 29, 2013 Author Share Posted January 29, 2013 BPV arrived today... Link to comment Share on other sites More sharing options...
acumenhokie Posted January 30, 2013 Author Share Posted January 30, 2013 Another good day for parts. Link to comment Share on other sites More sharing options...
acumenhokie Posted February 9, 2013 Author Share Posted February 9, 2013 AP Holder install. The 5 minute ghetto fab version. Link to comment Share on other sites More sharing options...
islandborn Posted February 9, 2013 Share Posted February 9, 2013 ^yeah but its ghetto-fabulous! Link to comment Share on other sites More sharing options...
BigBopper Posted February 9, 2013 Share Posted February 9, 2013 If you haven't already ... It's time to add WeatherTech floor mats to your mod list. :lol: AP Holder install. The 5 minute ghetto fab version. Link to comment Share on other sites More sharing options...
acumenhokie Posted February 9, 2013 Author Share Posted February 9, 2013 If you haven't already ... It's time to add WeatherTech floor mats to your mod list. :lol: I have the Subaru all weather mats (have weather tech in the forester). I make the Subaru earn its brand in the winter. Washes and vacuums are few and far between. Link to comment Share on other sites More sharing options...
Blizzard Posted February 10, 2013 Share Posted February 10, 2013 AP Holder install. The 5 minute ghetto fab version. Nice that's where I was planning on putting mine. Too much damn snow to deal with that right now. Link to comment Share on other sites More sharing options...
acumenhokie Posted February 10, 2013 Author Share Posted February 10, 2013 AP Holder install. The 5 minute ghetto fab version. When I installed it I never actually got in the car seat. When I eventually did I found that it was right behind the steering wheel. Ended up mounting it the same location but all the way to the left side of the vent. Only other change was making the wire wrap up and around b/c the way it came out in the second picture it was too tight a bend once moved to the left side of the vent. Link to comment Share on other sites More sharing options...
