jayjay Posted March 23, 2011 Share Posted March 23, 2011 i have a 98 legact gt wagon and i have notived that my drivers side floor is wet. the first thing i thought was the heater core, but the heat works fine, i dont smell or see any coolant. So what can be causing the floor to get wet? Link to comment Share on other sites More sharing options...
98LGTLover Posted March 23, 2011 Share Posted March 23, 2011 It is probably your sunroof drain. Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 23, 2011 Share Posted March 23, 2011 hmm. i should check this. my floor was wet. but then again it is slush season. Link to comment Share on other sites More sharing options...
Lookatmyrust Posted March 23, 2011 Share Posted March 23, 2011 http://legacygt.com/forums/showthread.php/just-purchased-98-lgt-wagon-coolant-positive-hydrocarbons-151027.html start here. things get to the sun roof by post 15 Link to comment Share on other sites More sharing options...
jayjay Posted May 8, 2011 Author Share Posted May 8, 2011 i can open that page 4 some reason... im assuming you have to remove the headliner... if so does anyone have a diy on the removal of the headliner? Link to comment Share on other sites More sharing options...
Kidcobalt Posted May 10, 2011 Share Posted May 10, 2011 Given that this is on the driver side, it's not your heater core. The same thing happened to me on my 1998 wagon, although on the passenger's side. After replacing the door weatherstripping, installing a missing fender liner, and blowing out the A/C evaporator drain hose, I decided to pull the cowl (the plastic piece under the windshield wipers). Sure enough a huge mound of dirt and sand was blocking the drain hole, thus forcing rain water not through the drain hose but rather between the firewall and the carpeting in the passenger compartment. After you have removed the cowl, the drain holes will be obvious. Blow them out with compressed air or ream the attached hoses with a wire, then pour water through the holes and see if there is immediately a puddle forming at the rear of the wheel arch. Link to comment Share on other sites More sharing options...
Bpgoodwin Posted May 20, 2011 Share Posted May 20, 2011 More than likely the sunroof drain, its either clogged or has come loose from a junction going down the "a" pillar. Link to comment Share on other sites More sharing options...
