Madjik_Man Posted March 17, 2011 Share Posted March 17, 2011 Dealer A just did my 60,000 mile maintenance. The found that there was oil in the spark plug tubes when they went to replace them. They recommended doing a valve cover gasket because the spark plug tube seals were leaking. I've never heard of this, was hoping to get some pro advice from you fine folks. Secondly, dealer A found that the shift shaft seal is leaking too. Again they recommended replacing it. Now, I still have an extended warranty through dealer B. I'm going in on Tuesday to see if they'll fix both of these things under warranty. I'm pretty sure they should. That said, total cost of repairs for both is nearly $1200 Lastly, here's another question: Dealer A went ahead and replaced the spark plugs per Subaru's 60,000 mile checklist. If oil is leaking onto them (presumably still), should I have dealer B replace the spark plugs if/when they do the warranty work on the valve cover gaskets? TIA Link to comment Share on other sites More sharing options...
Madjik_Man Posted March 21, 2011 Author Share Posted March 21, 2011 Sorry for the bump. Just trying to get a little info from you all who know a boatload more than me. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 21, 2011 Share Posted March 21, 2011 The plugs will be fine. They are sealed off from the oil. IMO those seals should all be covered by Subaru. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Madjik_Man Posted March 21, 2011 Author Share Posted March 21, 2011 Thank you very much. The dealer with which I have the ext. warranty has been very generous in terms of warranty work done to the vehicle. Link to comment Share on other sites More sharing options...
Madjik_Man Posted March 24, 2011 Author Share Posted March 24, 2011 Well, the dealer (with the warranty) found no oil in the tubes or any leakage from the shift shaft seal. Of course. They said drive it for a couple thousand miles and bring it back. I wonder if the first dealer cleaned it all up? And if so, how long would it take for oil to make it back into the spots where they saw it? Link to comment Share on other sites More sharing options...
burnout8488 Posted March 26, 2011 Share Posted March 26, 2011 My OEM tube seals AND shifter seal were both leaking. I replaced the VC gasket to fix that, and blasted around the shift seal with carb cleaner. After that, there was zero gear oil residue left, and it hasn't returned. You might be out of luck getting it replaced under warranty there if the first dealer cleaned it up. Link to comment Share on other sites More sharing options...
