Bob M. Posted March 13, 2011 Share Posted March 13, 2011 I'm interested in buying a used Legacy GT Limited wagon. I'm looking at model years 2005 thru 2007. Any recommendations or advice? I'm confused by some of the terminology used by Subaru. I came across a 2005 Legacy wagon called a XT. It was turbocharged with leather seats and a moonroof. I've never heard of the XT while doing my research, only the GT. Also, what is a Spec B? I've heard that only comes with the sedan but I'm not sure about that. Also, I've been confused by what some salesman say is a Legacy/Outback. I thought it was one or the other? Can it be both? I thought the Outback was higher off the ground than the Legacy. Also, I've never owned a Subaru before. How many miles is too many for a used Subaru legacy? I was hoping to find one with 40K~60K but most I've seen are higher mileage than that. At what mileage should I pass, where the car, engine, and transmission are most probably spent/used up? I'd like to have some years of low maintenance service, if possible. I know at a certain point and mileage, I will start having big repair bills but at what mileage is that most likely to occur? Any advice on this subject? Thanks, Bob M. Link to comment Share on other sites More sharing options...
Drift Motion Posted March 13, 2011 Share Posted March 13, 2011 XT = Outback Wagon very similar to the LGT Wagon SpecB is the god-almighty model... mileage thing is all depending on previous owner you can have a 30k miles car that isnt properly maintained and about to blow up vs a 100k miles car that is properly maintained that will last you much longer Link to comment Share on other sites More sharing options...
RabidWombat Posted March 16, 2011 Share Posted March 16, 2011 The biggest issue is the turbo tends to need replacement at around 100k. The timing belt, water pump, etc are a 105k service item, which results in a costly service. The Outback XT is basically a raised Legacy GT, the difference could be hard to see without seeing them side by side. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 17, 2011 Share Posted March 17, 2011 Legacy/Outback have always been tied together. Outbacks sit higher. They are the same chassis. In 05 and 06 you could buy a Legacy wagon, they only made the GT Wagon with a 5mt in 05. The Outbacks look different once you know the two cars. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Bob M. Posted March 20, 2011 Author Share Posted March 20, 2011 I've been trying to get up to speed with all the Subaru terminology and nomenclature as I'm shopping for my first Subaru. I found this on an Edmunds review: Let's recap: The Limited, which was never really limited, remains so, and although last year's non-Limited version was limited, it isn't anymore. Bob M. Link to comment Share on other sites More sharing options...
pcw8584 Posted March 20, 2011 Share Posted March 20, 2011 Cars101.com has a lot of good info on the differences between Legacies and Outbacks. Link to comment Share on other sites More sharing options...
