PearlBlueGT Posted March 11, 2011 Share Posted March 11, 2011 So I had P0011 and P0021 along with P0128 (thermostat) I've changed both OCV valves (got them from Fred Beans) cleared codes test drove car 2 times and on 2nd time P0021 and P0011 are back. I am at a loss at what to do now:icon_conf:confused: What should I do now? Do another oil change? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2011 Share Posted March 11, 2011 I think you need to clean the cam position sensors. That code is for to much advance of the cam timing. OCV's will slow the timing down, if I understand it right. My mechanic also said they remove the banjo filter and that seems to help on the 7 cars they've work on for those codes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
PearlBlueGT Posted March 11, 2011 Author Share Posted March 11, 2011 where are the cam position sensors located? Link to comment Share on other sites More sharing options...
Max Capacity Posted March 11, 2011 Share Posted March 11, 2011 I believe further back on the heads towards the firewall. That's what my Tuner said could be the problem when I got the P0011 and P0021 codes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
PearlBlueGT Posted March 12, 2011 Author Share Posted March 12, 2011 Does anyone know resistance specs for cam position sensor? Link to comment Share on other sites More sharing options...
Saeros Posted March 12, 2011 Share Posted March 12, 2011 I had this same issue last month. Took it to the mechanic and he replaced both OCV valves. About 2 days later, the same error code came up. I change my oil every 3000 miles, and only use synthetic but last time I did an oil change I wasn't able to get the filter off. So I was stuck, with a car with no oil in it...so I figured the filter should be fine for alittle while longer... I got to about 4k miles on the filter and that is when the error came up. Since changing the OCV valves didn't seem to fix it, I decided to pick up the tool needed and change the oil filter. The light went off, and hasn't come back on...that was 2 weeks ago. Wish I would have rememebered about the filter before I payed for new OCV's Link to comment Share on other sites More sharing options...
PearlBlueGT Posted March 12, 2011 Author Share Posted March 12, 2011 The car does run very rough at stop (when in gear) rpms are so low that it almost dies but it doesn't. If I put it in neutral it will smooth out and rough idle is almost unnoticeable. Link to comment Share on other sites More sharing options...
motorbykemike Posted March 12, 2011 Share Posted March 12, 2011 the ocv's are both fed w/ oil through a bajo bolt w/ the MUDDAFRIGGIN SCREEN in them ! check em Link to comment Share on other sites More sharing options...
PearlBlueGT Posted March 12, 2011 Author Share Posted March 12, 2011 I had this same issue last month. Took it to the mechanic and he replaced both OCV valves. About 2 days later, the same error code came up. I change my oil every 3000 miles, and only use synthetic but last time I did an oil change I wasn't able to get the filter off. So I was stuck, with a car with no oil in it...so I figured the filter should be fine for alittle while longer... I got to about 4k miles on the filter and that is when the error came up. Since changing the OCV valves didn't seem to fix it, I decided to pick up the tool needed and change the oil filter. The light went off, and hasn't come back on...that was 2 weeks ago. Wish I would have rememebered about the filter before I payed for new OCV's There's tool needed to change oil filter? As far as I know it comes off just like on any other vehicle. It is easily accessible from under the car. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted March 12, 2011 Author Share Posted March 12, 2011 I've read on here http://forum.ecutek.com/topic.asp?TOPIC_ID=1848 that OCV valves resistance should be 6-12 Ohms and my old ones are within spec ~8 Ohms so I just wasted ~$200 Link to comment Share on other sites More sharing options...
Saeros Posted March 14, 2011 Share Posted March 14, 2011 There's tool needed to change oil filter? As far as I know it comes off just like on any other vehicle. It is easily accessible from under the car. LoL, yea I tried for the better part of an hour to get that filter off. Last time I changed the oil I just hand tightened it like I always do but I could NOT get it off. So I had to resort to buying a filter wrench to get the stupid thing off. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted March 16, 2011 Author Share Posted March 16, 2011 the ocv's are both fed w/ oil through a bajo bolt w/ the MUDDAFRIGGIN SCREEN in them ! check em I took out banjo bolts that are next to OCVs but didn't see filters inside of them Link to comment Share on other sites More sharing options...
motorbykemike Posted March 16, 2011 Share Posted March 16, 2011 on our 05 the banjo on drivers side w/ screen in it is behind the timing cover/upper cam gear . pass side the banjo w/ screen that feeds turbo also feeds the ocv . not the banjos directly on the ocv . Link to comment Share on other sites More sharing options...
Draco-REX Posted March 16, 2011 Share Posted March 16, 2011 LoL, yea I tried for the better part of an hour to get that filter off. Last time I changed the oil I just hand tightened it like I always do but I could NOT get it off. So I had to resort to buying a filter wrench to get the stupid thing off. For future reference, you don't need a filter wrench for subaru oil filters that are stuck. Take a phillips screw driver and hammer it into the side of the filter and use the handle to break it free. Had to do this on a used car I bought. The previous owner had an opil ship change the oil and they must've use an impact to get that thing on.. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted March 16, 2011 Author Share Posted March 16, 2011 on our 05 the banjo on drivers side w/ screen in it is behind the timing cover/upper cam gear . pass side the banjo w/ screen that feeds turbo also feeds the ocv . not the banjos directly on the ocv . This helps, thanks Link to comment Share on other sites More sharing options...
