PutnamCO Posted March 2, 2011 Share Posted March 2, 2011 I recently noticed an exhaust leak coming from somewhere near the turbo, so yesterday, I took everything apart and replaced or treated (with copper gasket sealant) every gasket from the manifold to the y-pipe. This did not take care of the problem, and I am now pretty sure that the leak is coming from the flex section of my Megan Racing uppipe. I am well aware that MR pipes are POS, but unfortunately these were my first aftermarket purchases and I did not know better. I would like to know if there is anything I can do to salvage the pipe, or do I just need to get a new one. Thanks. Link to comment Share on other sites More sharing options...
planelazy Posted March 2, 2011 Share Posted March 2, 2011 Weld it maybe? I guess it depends where the leak is from.. but a new up pipe will only set you back about 150 dollars (more or less)... but that's one reason why I choose not to get a flexjoint.. I just went straight pipe Link to comment Share on other sites More sharing options...
BAC5.2 Posted March 2, 2011 Share Posted March 2, 2011 Buy a better uppipe. Fixing it isn't worth it. Put crap in, get crap out. A good, high quality flex joint won't leak and the pipe will be more reliable than a straight pipe. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
PutnamCO Posted March 2, 2011 Author Share Posted March 2, 2011 Thanks for the advice, that's what I figured but wanted to make sure. My MR uppipe and downpipe have caused me more problems than everything else on my car put together. I have had to weld the DP 3x because of cracking behind the flange, and had to add material by welding to try to make the gasket seal. Just a warning to anyone else thinking of buying their crap. Link to comment Share on other sites More sharing options...
CTATV Posted March 2, 2011 Share Posted March 2, 2011 done 30k miles of NYC and surrounding highways, tunnels, bridges, potholes in the last 9 months and not a single issue with my Invida catless UP. If you get it installed right a solid pipe wont work and once its installed properly, it also doesnt have a flex point which eventually will be a point of weakness... IMHO of course Link to comment Share on other sites More sharing options...
