penndotpal Posted February 25, 2011 Share Posted February 25, 2011 Not sure if anyone else was having issues or if this a new thing for 2011's 328Miles on the Tach and my sunroof doesn't close...or open...just kinda..STUCK! Dealer fixed it, it was out of alignment, probably just my car Link to comment Share on other sites More sharing options...
Magic Marker Posted February 25, 2011 Share Posted February 25, 2011 No issues on mine, but I've only tilted so far. Been too cold since October when I picked it up. 2011 Volvo S60T6 & 2013 Volvo XC60T6 Polestar Link to comment Share on other sites More sharing options...
Subytech Posted February 25, 2011 Share Posted February 25, 2011 Theres a TSB out for this issue I've fixed about 10 Legacy's and O/B's so far Link to comment Share on other sites More sharing options...
acumenhokie Posted February 25, 2011 Share Posted February 25, 2011 Theres a TSB out for this issue I've fixed about 10 Legacy's and O/B's so far Do you have the TSB info? I assume it covers all 5th gen Legacy? Link to comment Share on other sites More sharing options...
minuccims Posted February 26, 2011 Share Posted February 26, 2011 Do you have the TSB info? I assume it covers all 5th gen Legacy? Here's the link. First one is for 2011 and the second is for the 2010s. Just a brief description is listed but it gives enough info to ask more questions. Good luck http://techinfo.subaru.com/search/index.html Service Bulletin # 12-124-10 Bulletin Description:** If you encounter a customer complaint when opening the sunroof (the glass opens about one inch then stops, makes a squeak type sound and/or opens halfway then binds), the wedge cap may be out of alignment. If the wedge cap is too high on one side, it will cause the sunroof glass to bind, which will cock the glass. Refer to the service procedure to remedy the condition. ----------------------------------- Service Bulletin # 12-118-10 Bulletin Description:* If you encounter a vehicle with a concern of the sunroof stopping mid-travel when opening, it may be caused by an improperly adjusted sunroof glass panel. To correct the condition, a washer will need to be added to properly adjust the sunroof glass panel. Link to comment Share on other sites More sharing options...
Subytech Posted February 26, 2011 Share Posted February 26, 2011 theres also a earlier tsb about the back edge of the sunroof hole in the roof causing the sunroof to jam when it trys to retract downward before it moves back, I'll see if I can find it later. This concern seemed to be quite limited and only on the early cars, the TSB above is much more common Link to comment Share on other sites More sharing options...
penndotpal Posted February 27, 2011 Author Share Posted February 27, 2011 yeah it was an alignment issue, they took care of it. Link to comment Share on other sites More sharing options...
Falcor Posted May 12, 2016 Share Posted May 12, 2016 theres also a earlier tsb about the back edge of the sunroof hole in the roof causing the sunroof to jam when it tries to retract downward before it moves back, I'll see if I can find it later. This concern seemed to be quite limited and only on the early cars, the TSB above is much more common Sorry to bring back an old thread, but my car was built about the middle of 2009, so it's one of the early cars. I have had a problem with the sunroof jam/bind on the back edge of the hole in the roof for awhile. It will move up to vent, but binds when lowering to open. Sil-Glyde does help, but only for a short time. I took it to the dealer about 6 months ago and they said it needed a whole new sunroof, and my extended warranty didn't cover it ($1600). He said they used to fix it with a TSB, but now they are instructed to replace the whole thing. Do you remember anything about that TSB? Link to comment Share on other sites More sharing options...
