Scanyland Posted February 24, 2011 Share Posted February 24, 2011 So I have noticed today that when my car is idling, like at a stop light or just in park, the car tends to shake quite alot, not like pieces falling off shaking but it is fairly rough. I was just wondering if this is common or not, it is the 2.2 brington automatic. I dont know if it an affect of the cold either or not. Link to comment Share on other sites More sharing options...
Feldman Posted February 24, 2011 Share Posted February 24, 2011 doesn't sound normal, when's that last time you checked/changed your spark plugs and wires? some fuel injector cleaner couldn't hurt either Link to comment Share on other sites More sharing options...
Baddog Posted February 24, 2011 Share Posted February 24, 2011 My auto does this at times too. Not sure why. Trans could be getting tired. Sometimes it vibrates normal then it gets kinda rough till you get moving again. I am having my engine pulled sometime within the next month and am going to put in new engine mounts and a new transmission mount. I am hoping that is the issue but we will see. Link to comment Share on other sites More sharing options...
kushmastercain Posted February 24, 2011 Share Posted February 24, 2011 just put in a jdm motor into my 98gt and it misses at idle too changed my plugs and wires too bosch and still does it so idk? Link to comment Share on other sites More sharing options...
Baddog Posted February 24, 2011 Share Posted February 24, 2011 Bosch is a no no on these cars. Link to comment Share on other sites More sharing options...
Scanyland Posted February 24, 2011 Author Share Posted February 24, 2011 I honestly dont know when the spark plugs were changed, so I'll give that a try and will also try cleaning the fuel injector. Link to comment Share on other sites More sharing options...
Kennyfvholla Posted February 24, 2011 Share Posted February 24, 2011 Mine does the same thing, but only while in gear and stopped. No vibration at all while in park or neutral. I replaced the engine mounts about two weeks ago, and have had no vibration since. My car had around 157k miles on it. Link to comment Share on other sites More sharing options...
johnegg Posted February 24, 2011 Share Posted February 24, 2011 i know the answer, but you won't believe me. test: put it in ''N'' and it will stop shaking. it's the after market axles. (the car didn't do this when it was new.) the joints on the after market axles don't ''float'' as well / easily / freely as the subaru axles. so they tranmit the trans / engine vibration to the wheels and the rest of the car. replace your axles with subaru OEM (way too expensive to buy new) from a salvage yard and reboot them before you install them and your problem will be solved. subaru axles will last almost forever if the boots are kept greased and replaced promptly when torn and before they let the dirt in. or buy reman axles from a GOOD re-builder that uses good quality parts. there are a few around. the reality is that the boots, labor and mess of rebooting is the same or more than the cost of an after market replacement form the parts store which will have a life time warranty. so we all go for the cheaper, easier solution. re-boot subaru, don't replace with cheap. i said you wouldn't believe me. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 24, 2011 I Donated Share Posted February 24, 2011 Interestingg info johnegg Sent from my Android powered HTC HD2 -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Kennyfvholla Posted February 24, 2011 Share Posted February 24, 2011 then that would be the difference between his problem and mine? I checked with the original owner who gave me my car, and he said that the axles have never been replaced. Just the boots. Link to comment Share on other sites More sharing options...
Baddog Posted February 24, 2011 Share Posted February 24, 2011 So we need to find CV half shafts. Link to comment Share on other sites More sharing options...
