IrishLt Posted February 18, 2011 Share Posted February 18, 2011 Yes i did the insta-noob, post before you search....but i need a solid answer and soon so i know what to grab. As i'll have one day to work on the car for like a 3week period.....Anyways, i popped a D@mm SES light, flashed at first now is just solid. Had it read and it showed as a cyl 3&4 misfire....the cylinders aren't misfiring. I know Crankshaft sensors sometimes cause that...but most of my car knowledge is domestic and none of it is 4 cylinder knowledge let alone H4. Any and all help appreciated. Thanks in advance -L.T. Car is as follows. 97 legacy gt 2.5 m/t Link to comment Share on other sites More sharing options...
subikid90 Posted February 18, 2011 Share Posted February 18, 2011 The best bet with these problems is to go though the FSM and check for sensors working. http://www.main.experiencetherave.com/subaru_manual_scans/1997_Legacy_FSM/ Here is a link to the FSM for you car. I have heard of the crank sensor causing false codes before so it is possible. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
johnegg Posted February 18, 2011 Share Posted February 18, 2011 first swap the wires front to rear, see if the misfire moves to 1 & 2. my next guess is the coil. it is split front, 1 & 2, rear 3 & 4. or maybe the igniter. Link to comment Share on other sites More sharing options...
Zues Marine Posted February 21, 2011 Share Posted February 21, 2011 +1 to the coil Link to comment Share on other sites More sharing options...
IrishLt Posted February 21, 2011 Author Share Posted February 21, 2011 Thanks guys, I'm thinking all just do the whole ignition system from coil to plug. Won't hurt anything, I just knew that some sensors would do weird codes sometimes as i didnt feel any misfires and its not rough or done it again after 3 days. So here's hoping its something little and dumb. -LT Link to comment Share on other sites More sharing options...
