cypher0117 Posted February 14, 2011 Author Share Posted February 14, 2011 I had a hell of a time finding Pilot Sports in a 225/55/17 too. I think the Outback is the only car on the road that uses that tire size. That said, I love the tires. I thought the tolerance listed in the manual was more than 1/32" though. I thought it was 1/16 or 1/8. I also love the tires too. the 1/32 is an approximate for the tread depth. I probably should have been more clear though. on a 215/45/r17 tire, 1/32" tread depth is .2 to .25 inches in circumference (depending on actual inflated tire diameter) and assuming you are going from 10/32 to 9/32. There is more tolerance in tire-to-tire tread depth the more you wear off the tread. Had some more words with sears. Looks like they found a tire somewhere and would have it to me by early next week. That said I will still need to measure the circumference of the mounted tires to make sure they are all within the 1/4" tolerance. Now I need to find some rims that will look good on an ABP LGT. Link to comment Share on other sites More sharing options...
BAC5.2 Posted February 14, 2011 Share Posted February 14, 2011 For rims, Rota Gravels. For the tire issue, try to find a local race shop that has a shaving machine. Some do, and Tire Rack might be able to recommend one to you. See if they can skim off 1/32. Or, go see if you can do an extended test drive on a used Scion TC (since they are 5x100). Mount your one wheel to the front and do a big ole burnout. Measure and repeat until you have applied an artificial several thousand miles to the tire and worn off that 1/32! [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
cypher0117 Posted February 15, 2011 Author Share Posted February 15, 2011 For rims, Rota Gravels. For the tire issue, try to find a local race shop that has a shaving machine. Some do, and Tire Rack might be able to recommend one to you. See if they can skim off 1/32. Or, go see if you can do an extended test drive on a used Scion TC (since they are 5x100). Mount your one wheel to the front and do a big ole burnout. Measure and repeat until you have applied an artificial several thousand miles to the tire and worn off that 1/32! I've heard very mixed reviews about rotas. I've thought about the burnout thing...but with someone i know and not a test drive vehicle. Link to comment Share on other sites More sharing options...
GTurabus Posted February 15, 2011 Share Posted February 15, 2011 Where are you located? I am putting up for sale my winter set up, a full set of tires and rims, Dunlop Wintersport 3D 225-40 18 with less than 15,000 miles and plenty of tread left, with Rota Tarmac 3 18 x 7.5 48 offset, clears Brembo's, no curb rash. I am putting together a for sale thread, just took pictures, can email as needed. I will try to post the tire thread this evening. Just giving you a heads up. I traded in my spec B last week and have a bunch of parts going up for sale. Link to comment Share on other sites More sharing options...
cypher0117 Posted February 16, 2011 Author Share Posted February 16, 2011 I just picked up the new tire from sears. Measured the circumference and now confused. The new tire, which measures 10/32 tread depth is 1/8" smaller circumference than all my other tires which are 9/32. Keep in mind this is a new unmounted unpressurised tire. How much do new tires stretch when they are first put on? Link to comment Share on other sites More sharing options...
BAC5.2 Posted February 16, 2011 Share Posted February 16, 2011 A lot. You can't compare an unmounted tire to a mounted tire. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
cypher0117 Posted February 19, 2011 Author Share Posted February 19, 2011 i agree with your logic that I shouldn't measure the tires when they are not mounted and pressurized. However, I'm still confused. I just had all of the tires mounted and balanced and remeasured. The new tire is 1/4" smaller circumference than the old tires. How long does it take the new tire to stretch? Link to comment Share on other sites More sharing options...
