rsmoove Posted February 7, 2011 Share Posted February 7, 2011 When you take your car to get the alignment done, should it correct your steering wheel alignment as well? Or is it only for camber, caster, and toe? In other words, if your steering wheel is slightly turned when you are driving straight, should a realignment correct this? Link to comment Share on other sites More sharing options...
underground000 Posted February 7, 2011 Share Posted February 7, 2011 Yes an alignment will correct it 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
rsmoove Posted February 8, 2011 Author Share Posted February 8, 2011 Cool. Thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted February 8, 2011 Share Posted February 8, 2011 As long as the guy knows what he's doing... Is your tire pressure OK on both front tires ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rsmoove Posted February 9, 2011 Author Share Posted February 9, 2011 As long as the guy knows what he's doing... Is your tire pressure OK on both front tires ? Yeah, it's where it should be. Link to comment Share on other sites More sharing options...
