Lookatmyrust Posted January 20, 2011 Share Posted January 20, 2011 i drove it in to the garage to put new rear brakes in and when i was done i went to start it and i let of the starter too early. it started a little bit and died. and now it will not fire. can these motors flood? how long should i wait. what can i do... can i take out the fuel pump fuse and turn it over to try and get a spark to clear the cylinders? Link to comment Share on other sites More sharing options...
jamesm113 Posted January 21, 2011 Share Posted January 21, 2011 i've heard flooring it and cranking it will shut off fuel flow, not sure if that applies to subarus though Link to comment Share on other sites More sharing options...
mwiener2 Posted January 21, 2011 Share Posted January 21, 2011 let the car sit for 15-20 min and try again. Sometimes they just get grumpy. Holding the gas pedal all they way to the floor while cranking is how you clear a flood on a fuel injected car. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Lookatmyrust Posted January 21, 2011 Author Share Posted January 21, 2011 got it.. thanks. Link to comment Share on other sites More sharing options...
Zues Marine Posted January 22, 2011 Share Posted January 22, 2011 you could remove the plugs, disconnect the fuel pump and crank it.. i just did this yesterday Link to comment Share on other sites More sharing options...
