bondad Posted January 20, 2011 Share Posted January 20, 2011 I recently bought a 93 Sport Sedan Turbo. Whenever the heat is on the car smells like exhause. There IS a small leak at the valve cover so maybe the oil is dripping on the manifold and that's the smell. Has anyone else encountered this problem or have any idea what else could cause the issue? Link to comment Share on other sites More sharing options...
LongHiway Posted January 20, 2011 Share Posted January 20, 2011 Small exhaust leak in the manifold? Try turning off the air recirculation see if the smell lessens. You may lose some brain cells if this is bad enough.. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted January 21, 2011 Share Posted January 21, 2011 These cars don't have an air circulation button, its all automatic and tied in with the heater controls. Its got to be an exhaust leak somewhere. With the engine running have a friend hold a rag over the tailpipe while you get under the car and search for leaks. Be careful not to burn yourself on the hot exhaust or inhale too much exhaust gas. If the valve cover was leaking oil onto the manifold it would smell more like you left the plastic wrapper on a wax candle and lit it anyway. Link to comment Share on other sites More sharing options...
sqc151 Posted January 21, 2011 Share Posted January 21, 2011 check the firewall for missing gromets. exhaust fumes can make there way thru those holes and into the cabin. Link to comment Share on other sites More sharing options...
pfrancz Posted March 6, 2011 Share Posted March 6, 2011 That's what we have happening, smells like candle wax when first starting with heat on, recirc air stops the smell. Dealer checked today with ASE trained folks and saw no leaks. I know they would sell us a gasket if they could find a leak? Still puzzled. Thx for the forum Link to comment Share on other sites More sharing options...
