izdizef Posted January 18, 2011 Share Posted January 18, 2011 Found a complete suspension set with the struts springs top mounts etc that came off of an 06 STi. I was thinking about installing them onto my BK legacy. Has anyone done this? I wanted to know how much of a drop it would give me, and if the ride would be too stiff for daily driving. Also, the parts came off of a sedan. Is this a no go? I figure I can just add some of those rear shims if I get any sag. Link to comment Share on other sites More sharing options...
carnumber19 Posted January 18, 2011 Share Posted January 18, 2011 I am pretty sure you can only use the STi suspension up through 04 Link to comment Share on other sites More sharing options...
whitetiger Posted January 18, 2011 Share Posted January 18, 2011 he can go up through 07 i believe. 08+ has the new suspension setup. Link to comment Share on other sites More sharing options...
subikid90 Posted January 18, 2011 Share Posted January 18, 2011 Only 04 sti suspension can be used on a bd/bk. 02-07 wrx stuff can also be used. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
whitetiger Posted January 18, 2011 Share Posted January 18, 2011 how is the 05-07 sti suspension different than the 05-07 wrx? Link to comment Share on other sites More sharing options...
subikid90 Posted January 18, 2011 Share Posted January 18, 2011 On the rear struts the bolt holes are further apart where it connects to the hub because it is a 5x144 hub. I have seen people re drill them, but seems like a lot of work and kinda unsafe. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
whitetiger Posted January 18, 2011 Share Posted January 18, 2011 ah. did not know that. Link to comment Share on other sites More sharing options...
izdizef Posted January 19, 2011 Author Share Posted January 19, 2011 thanks for that. definately not interesting in any re drilling down there Link to comment Share on other sites More sharing options...
izdizef Posted January 19, 2011 Author Share Posted January 19, 2011 Only 04 sti suspension can be used on a bd/bk. 02-07 wrx stuff can also be used. when you say 04 sti you mean all years up to 04 right? or is it just that one year? Link to comment Share on other sites More sharing options...
kaz98gt Posted January 19, 2011 Share Posted January 19, 2011 the 04 sti was the first year in the states. wrx hit the shores in 02, but the sti came in 04, then immediately switched to the 5x114.5 bolt pattern for the 05 model. Link to comment Share on other sites More sharing options...
KuNomn Posted January 19, 2011 Share Posted January 19, 2011 kinda surprised nobody has done this already. Check the stickied suspension thread up top Link to comment Share on other sites More sharing options...
vicdeng Posted January 19, 2011 Share Posted January 19, 2011 I got the 02 JDM STI spec C S202 suspension laying around, waiting to be install. I am thinking what kind of butt spacer i need. Link to comment Share on other sites More sharing options...
stiwanabe Posted January 19, 2011 Share Posted January 19, 2011 I got the 02 JDM STI spec C S202 suspension laying around, waiting to be install. I am thinking what kind of butt spacer i need. I have 04 STi suspension on my wagon with 3/8" spacers. I didnt wanna do the extended studs but if i had to do it again Id go 1/2" with the studs b/c the rear still sits just a TAD low with the 3/8" spacers. Link to comment Share on other sites More sharing options...
vicdeng Posted January 19, 2011 Share Posted January 19, 2011 Good to know. You got pictures? thanks for the information. Link to comment Share on other sites More sharing options...
izdizef Posted January 19, 2011 Author Share Posted January 19, 2011 Will stock sedan WRX springs give me a drop? I have heard mixed responses. Maybe someone who has/is running this setup can chime in. Link to comment Share on other sites More sharing options...
vicdeng Posted January 19, 2011 Share Posted January 19, 2011 Will stock sedan WRX springs give me a drop? I have heard mixed responses. Maybe someone who has/is running this setup can chime in. Not much, very minimal. But you might able to increase some handling. Link to comment Share on other sites More sharing options...
carnumber19 Posted January 19, 2011 Share Posted January 19, 2011 Will stock sedan WRX springs give me a drop? I have heard mixed responses. Maybe someone who has/is running this setup can chime in. I think a big reason is variation in the suspensions when they are installed. If your riding on really old, worn out, and saggy sprints the WRX suspension will probably result in a lift from where you were. Likewise, if the WRX suspension is old and worn out, and yours is in relatively good shape it will probably result in a drop. I haven't found exact measurements but I'm pretty sure the overall height of the strut assembly, etc. is pretty close to the same. Hence, the pretty varied results I've read about. Just my running theory, but it makes sense in my head. All that being said, if you swap in the WRX strut assemblies and it doesn't give you the height your looking for (in a drop, if that's what your after), you can always grab a set of Eibach springs for the year WRX suspension you have and get the drop from those. Link to comment Share on other sites More sharing options...
subikid90 Posted January 19, 2011 Share Posted January 19, 2011 Will stock sedan WRX springs give me a drop? I have heard mixed responses. Maybe someone who has/is running this setup can chime in. I am running on 04 WRX take offs with around 50-60k. They ride a million times better than my old worn out stock stuff. I didnt see and raise or lowering really. You feel more bumps but nothing like coilovers. Worth the $180 I paid easily. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
