mmeek2003 Posted January 17, 2011 Share Posted January 17, 2011 Hi im new here i have a 1990 legacy awd and it runs like a champ...however the heat blower motor does not work the tach quit gas gauge doesnt work all the time and the auto seatbelts dont either nor the sunroof i need the gas and blower motor to work is this a computer problem? no enginne light is on and cant find any codes being thrown. any ideas? Link to comment Share on other sites More sharing options...
Legacy Wagon Posted January 17, 2011 Share Posted January 17, 2011 The blower motors go out. It's an easy swap though. Maybe a 20 minute job. No clue about the tach unless the speedo went out too :/ The gas gauge thing happened with my friend. After 50 miles it'd say it was empty from full. Just something he dealt with. Maybe the float in the fuel pump is bad. As long as the auto seatbelts are stuck in the up position I wouldnt worry about it. My passenger side is broken and I love that it is since my door lock broke the other day and I have to unlock the passenger side to get in. The sunroof may work if you hit right behind it on the roof. My friend used to do that all the time with his. As long as it doesnt leak I wouldn't use it anymore. I'd say take out the blower motor and test it on the battery to see if it will spin. (it jumps pretty hard so hold on tight) If it works it's probably the connectors on the back of the a/c knobs. The gas...maybe a new fuel pump? That's my only idea. I'm not too sure about that one. I doubt the computer is the issue. It's a 20 year old car. Those things seem more common from what I'm seeing. Good luck, dude. Link to comment Share on other sites More sharing options...
sqc151 Posted January 17, 2011 Share Posted January 17, 2011 legacy wagon gave a some good tips on the blower. about the gauge and tach, it may be the cluster itself. auto or manual? Link to comment Share on other sites More sharing options...
mmeek2003 Posted January 17, 2011 Author Share Posted January 17, 2011 Its a manual Link to comment Share on other sites More sharing options...
