AZZMAN Posted September 27, 2012 Author Share Posted September 27, 2012 So here is an update like 18 months later... Took car to the dealer shortly after, they thought it was a broken 5th gear as all the other gears worked fine. They said it would need a need a trans re-build. I always wanted to kick it up a notch with with lower springs, new clutch, bigger brakes, bigger turbo, window tint and did not have the money for all that. Then combine a 85 mile commute each day with 93 octane fuel I decide to garage the car. I have changed the oil once since then and I drive the car around for a few miles about once a month. It still runs fine. Anyways... my new commute is about 8 miles a day soooo now I have to decide on all the parts and get the Subie back on the road in a few months. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 27, 2012 Share Posted September 27, 2012 Welcome back... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AZZMAN Posted September 27, 2012 Author Share Posted September 27, 2012 Thank you my friend. Now I have the task of cruising the threads to find me some good ideas and parts. Link to comment Share on other sites More sharing options...
AZZMAN Posted April 27, 2016 Author Share Posted April 27, 2016 Rubuilt trans last Summer. Now the car is listed for a best offer in the cars for sale section, with an engine problem, cracked piston rod is the diagnosis... Link to comment Share on other sites More sharing options...
