fiber_tek Posted January 14, 2011 Share Posted January 14, 2011 95 Legacy Outback 2.2 5MT, when the car is cold it starts right up but runs like it is too rich. It clears up with in about 10-15 seconds. Any ideas? I just replaced the front 02 sensor because I was getting a P0420 code and that is cleared up now and the problems that came with that. But this cold start problem is a little annoying and may be the cause of my 20mpg average. I would think that this car would get better mileage. Link to comment Share on other sites More sharing options...
carnumber19 Posted January 14, 2011 Share Posted January 14, 2011 When you say it runs like it is too rich, can you describe that? Just rough? Bogging down a little? Strong unspent fuel smell in the exhaust? Link to comment Share on other sites More sharing options...
fiber_tek Posted January 14, 2011 Author Share Posted January 14, 2011 It feels like it is running on 2 of the 4 cylinders. I haven't smelled any fuel, but haven't got out to smell it either. I just start it and it runs kind of like it is flooded then it clears up and runs fine. Link to comment Share on other sites More sharing options...
SebGT98 Posted January 14, 2011 Share Posted January 14, 2011 I'm having the same problem with my 98 gt, when I start it after a night of sitting, it starts really rough and idles at about 800, which is odd for the first start up of the day, usually sits at about 1500 when I first turn it on. The car shakes and sounds terrible when it is in this idle, but like you said, it only lasts for a little bit then it clears up and is fine. Link to comment Share on other sites More sharing options...
carnumber19 Posted January 14, 2011 Share Posted January 14, 2011 I'm having the same problem with my 98 gt, when I start it after a night of sitting, it starts really rough and idles at about 800, which is odd for the first start up of the day, usually sits at about 1500 when I first turn it on. The car shakes and sounds terrible when it is in this idle, but like you said, it only lasts for a little bit then it clears up and is fine. Sounds like it could be the idle air control valve (or whatever the Subaru nomenclature is on it). It's a valve that can open or close to allow extra air past the throttle body when it's closed than during regular idle. It allows the car to idle slightly higher during cold starts. If your car is idling at its usual idle immediately after a cold start, I would suspect this to be the culprit. Try cleaning it out, if that doesn't work, replace it. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted January 14, 2011 I Donated Share Posted January 14, 2011 Did you use an aftermarket or OEM o2 sensor? I had problems simular to this when I put an Autozone o2 sensor on my car (upstream). It went away when I swaped it out with an OEM one -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
fiber_tek Posted January 14, 2011 Author Share Posted January 14, 2011 Did you use an aftermarket or OEM o2 sensor? I had problems simular to this when I put an Autozone o2 sensor on my car (upstream). It went away when I swaped it out with an OEM one I installed an OEM 02 sensor from the Subaru Dealer. Link to comment Share on other sites More sharing options...
