vicdeng Posted January 11, 2011 Share Posted January 11, 2011 Hi, guys, i am ready to do the JDM projector conversion, and i am using DDM HID h1 kit for low beam, keep the high beam in the projector as it is. i don't have plan for the driving light yet and need advice. I made a lil wiring diagram to show you guys before actually doing it. Any comments are welcomed. thanks http://i210.photobucket.com/albums/bb14/vicdeng/Wiring.jpg?t=1294711432 Link to comment Share on other sites More sharing options...
vicdeng Posted January 11, 2011 Author Share Posted January 11, 2011 no one? Link to comment Share on other sites More sharing options...
subikid90 Posted January 11, 2011 Share Posted January 11, 2011 You dont split the ground. The way the lights work it by grounding the bulb, so when you turn your high beams on you ground out the high beam. But your wiring diagram is correct, just power instead of ground. Here is some pictures and a DIY for it http://sl-i.net/FORUM/viewtopic.php?f=39&t=5941&hilit=projector+wiring For the city light I wired it to my "DRL's," and no longer have my side markers (amber) light up besides for blinker. The JDM lights only have a 1156 bulb socket for the turn signals, only blink, so I used that instead of modifying my USDM socket. Hope this helps. If you have any questions just ask -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Zues Marine Posted January 12, 2011 Share Posted January 12, 2011 ^ this /thread Link to comment Share on other sites More sharing options...
vicdeng Posted January 12, 2011 Author Share Posted January 12, 2011 You dont split the ground. The way the lights work it by grounding the bulb, so when you turn your high beams on you ground out the high beam. But your wiring diagram is correct, just power instead of ground. Here is some pictures and a DIY for it http://sl-i.net/FORUM/viewtopic.php?f=39&t=5941&hilit=projector+wiring For the city light I wired it to my "DRL's," and no longer have my side markers (amber) light up besides for blinker. The JDM lights only have a 1156 bulb socket for the turn signals, only blink, so I used that instead of modifying my USDM socket. Hope this helps. If you have any questions just ask So what you mean is i don't need to share ground, just positive for high beam, and leave the ground for low beam. That means i don't need to split the ground and just leave the ground for low beam to use. Link to comment Share on other sites More sharing options...
subikid90 Posted January 12, 2011 Share Posted January 12, 2011 On your picture what you called positive is really a ground and vise versa. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
