MA44AL Posted January 8, 2011 Share Posted January 8, 2011 Hey guys, Just picked up an 05 liberty and got a good deal on some used wheels however i realise that ill have to run roughly -2.5 camber at the front and -1.5 at the rear. Im not running coilovers and don't really intend to as its just a 2.5L NA so just a daily driver basically. Anyway was just wondering if it was possible to achieve those figures with just some after market camber bolts or camber kit? Cheers Link to comment Share on other sites More sharing options...
underground000 Posted January 8, 2011 Share Posted January 8, 2011 Whiteline KCA399 These are for the back camber, may be able to get -1.5, I have no experience with them I was able to get -1.2 on the front stock camber bolts w/ no suspension mods Dont know if you can get these in your country, for the front http://www.ingallseng.com/ part numbers: Upper bolt 16mm - 2dreegree adjstment 81280 - 16mm Fastcam™ Bolts Lower Bolt 14mm - .75degree adjustment 81260 - 14mm Fastcam™ Bolts 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
underground000 Posted January 9, 2011 Share Posted January 9, 2011 bump, anyone else going to chime in? 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
Th3Franz Posted January 9, 2011 Share Posted January 9, 2011 Sell the wheels and find some that fit properly. You won't be able to get enough camber up front with stock suspension, even with all camber bolts. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
MA44AL Posted January 10, 2011 Author Share Posted January 10, 2011 If I have to I will run bc coilovers. Was just wondering with some lipping and pumping of the guards if I could run them with just some camber bolts and a camber kit though Link to comment Share on other sites More sharing options...
