datdookie Posted January 5, 2011 Share Posted January 5, 2011 Posting this on the sites i go to. Ej25D Block So I'm trying to put my bottom block together but the one of the threading on/inside the driver side block is a little stripped and i need to know the thread count. Picture reference from Brydon, I hope you dont mind me using this but if you do please tell me and ill take it down. This is the wrong side of the block but to give you a picture of what im talking about its those holes which the bolts go into to combine the two halves together. http://i97.photobucket.com/albums/l240/brydonfoster/assembly17.jpg Again taken from Brydon, but if this helps its A. http://i97.photobucket.com/albums/l240/brydonfoster/Case_bolts.jpg Sorry i didnt search or anything so, chew me up if you want, i need to get this bloc together. Oh and its a Link to comment Share on other sites More sharing options...
johnegg Posted January 5, 2011 Share Posted January 5, 2011 just check the bolts you removed. Link to comment Share on other sites More sharing options...
datdookie Posted January 5, 2011 Author Share Posted January 5, 2011 Bolts are perfect, I know the bold should be the same patterns but im not finding any information on the thread of that either. Link to comment Share on other sites More sharing options...
KuNomn Posted January 6, 2011 Share Posted January 6, 2011 bring one of the good bolts to your local hardware store or lowe's/home depot and they'll be able to help you out Link to comment Share on other sites More sharing options...
Zues Marine Posted January 6, 2011 Share Posted January 6, 2011 just check the bolts you removed. why not just do this? Link to comment Share on other sites More sharing options...
johnegg Posted January 6, 2011 Share Posted January 6, 2011 take a bolt with you to the store, figure out the threads, buy the matching tap. or look up the part number on the link below and maybe that will give you some info: http://opposedforces.com/parts Link to comment Share on other sites More sharing options...
