HankG Posted January 5, 2011 Share Posted January 5, 2011 I just bought my first Subaru, a 1995 Legacy Outback. The transmission, a TY752VAAAA, is dead, so I need to know which transmissions are compatible with my car. Unfortunately, I know nothing about Subarus besides what the info plate in the engine bay told me, so I'm fairly lost. Will any TY752 work, or do I need the specific one I have now? Thanks for any help. Link to comment Share on other sites More sharing options...
rao Posted January 5, 2011 Share Posted January 5, 2011 Welcome! There are lots of transmissions that will work. Your best bet is to look and ask around at http://www.nasioc.com in the Subaru conversions sub-forum. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
HankG Posted January 5, 2011 Author Share Posted January 5, 2011 Thank you for the reply. I posted the question over at NASIOC as well, but I was wondering if you could be any more specific about which transmissions would work. Is it just that any MT5 will work fine? Link to comment Share on other sites More sharing options...
frank_ster Posted January 5, 2011 Share Posted January 5, 2011 the only thing special about the trannys are the front diffrential gear ratio( built into the tranny ). if the front diff doesn't match your rear diff the tranny will break. outbacks typically a step lower gear ratio then the legacy's and imprezas Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
HankG Posted January 5, 2011 Author Share Posted January 5, 2011 Does it matter if it's a pull clutch or a push clutch? Link to comment Share on other sites More sharing options...
HankG Posted January 6, 2011 Author Share Posted January 6, 2011 I've done some more research with what you guys have said and this is what I've come up with. I can use any 5MT push clutch transmission with a 4.111 gear ratio. If that is the case, then this list (http://www.gearhack.com/docs/Subaru%20T ... 0Chart.pdf) should have all the transmissions that I can use. Am I correct or am I missing something? Just in case someone else ends up in my situation, that chart is in fact incorrect. The TY752VAAAA transmission has 3.90 gearing. Link to comment Share on other sites More sharing options...
