babybaluga32 Posted January 5, 2011 Share Posted January 5, 2011 2.2 No cat Turbo 2.5" exhaust I just read that some modded 2.5's backfire, they said it wasn't a bad thing, but I'm curious if its bad for my turbo? It's once the rpm's drop after hard acceleration. They aren't huge backfires. I have a aem fpr. Its generally on 52 psi Link to comment Share on other sites More sharing options...
KuNomn Posted January 5, 2011 Share Posted January 5, 2011 Anti-lag system goooooooooooooooo but seriously, you're running 52 psi? *edit* Oh, you mean your fuel pressure lol. Nevermind Link to comment Share on other sites More sharing options...
ehsnils Posted January 5, 2011 Share Posted January 5, 2011 Backfiring is an indication that the engine runs rich. It may well be that the ECU and sensors doesn't keep up with your throttle handling or that you need a tune. If it isn't serious it's no big deal, but I see it as an indication that you should do a tune if you can. Link to comment Share on other sites More sharing options...
Zues Marine Posted January 6, 2011 Share Posted January 6, 2011 you'll have to go to the other side of the state for a worthy tune too, theres very little people around here that do it right Link to comment Share on other sites More sharing options...
WESTcoast Posted January 6, 2011 Share Posted January 6, 2011 drive down to cali, there in the bay area there are about 15 subaru specialist shops that do tunes and crank out good numbers! Link to comment Share on other sites More sharing options...
subikid90 Posted January 6, 2011 Share Posted January 6, 2011 Portland has a few also, closer drive lol. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
