frank_ster Posted February 23, 2013 Share Posted February 23, 2013 the book says 1/4" to 3/8" with 22 lbs force Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
IceCold81 Posted February 23, 2013 Share Posted February 23, 2013 Ya know what for good measure I'll have to take another peak... Yea 1/2 was a total approximation from what I remember from weeks ago lol. But thanks for posting those numbers (Hmmm how the HELL am I going to manifest a 22lb level of resistance outside of literally stacking plated weights onto something? ) Link to comment Share on other sites More sharing options...
frank_ster Posted February 23, 2013 Share Posted February 23, 2013 push you thumb on to bathroom scale untill it reads 22 lbs .. then try to reproduce that ! or just tighten it a lil more ! jsut to try .. even make it to tight see if the problem goes away ,, at worst you can loosen it again. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
IceCold81 Posted February 23, 2013 Share Posted February 23, 2013 Be back soon with an update... (By soon probably DAYS ) Link to comment Share on other sites More sharing options...
byurocks10 Posted February 23, 2013 Share Posted February 23, 2013 I had the same problem.... belt squeal was BAD. I could hear my wife leaving in the morning for work because it would squeal so bad. Took it to one mechanic, he said i needed a new psp because the pump was freezing up. Took it to another, he put a new belt on, tightened that thing down, and it was as good as new. $30. Link to comment Share on other sites More sharing options...
IceCold81 Posted February 23, 2013 Share Posted February 23, 2013 Yea I'm gonna compare it to stock recommendation on tightness... Mine isn't a belt squeal issue (also a brand new belt), car starts fine, no noise, the pump just freezes intermittently when under pressure of something like a stand still wheel turn or tight parking job... which is SOOOO much less now, after the flush Link to comment Share on other sites More sharing options...
