Mark34 Posted December 20, 2010 Share Posted December 20, 2010 To all you tuning experts, please help. I'm going in for a dyno tune next week and trying to figure out if it is worth it for me to install an aftermarket up pipe first. I know I don't need to for cat elimination, but would it be worth it for me to do it now? Car is '07 LGT. Mods Perrin one piece catted dp, IPR tmic, Cobb intake, Cobb bpv, grimmspeed boost control solenoid (going on right before tune). Only data I've seen suggests possible 17% flow increase, is that enough at this stage to make it worth it? And if the answer is yes, I was looking either HKS or GrimmSpeed. Thanks. Link to comment Share on other sites More sharing options...
Drift Motion Posted December 20, 2010 Share Posted December 20, 2010 IIRC 07+ LGT have catless uppipe OEM so no point of getting an aftermarket one Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted December 20, 2010 Share Posted December 20, 2010 My understanding is that the OEM catless UP offers great spool and works very well. 17% flow increase could also effectively reduce the exhaust charge slowing spool. If you are running vf40/46 I would not bother. Unfortunately for me, I've got an 05 so I went aftermarket. Link to comment Share on other sites More sharing options...
m sprank Posted December 20, 2010 Share Posted December 20, 2010 You do not need an aftermarket uppipe. Your mods do not require any more flow. Link to comment Share on other sites More sharing options...
Th3Franz Posted December 20, 2010 Share Posted December 20, 2010 I switched to the Grimmspeed coated up-pipe from an OEM STI up-pipe. I switched because the flanges on the STI pipe warped and it started leaking. I did notice an improvement in spool with the Grimmspeed pipe after I did the swap. The car builds boost slightly quicker. It's not a night and day difference, but I was pleased that it was an improvement. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Mark34 Posted December 20, 2010 Author Share Posted December 20, 2010 Thanks for the input. I will stick with the stock for now. Link to comment Share on other sites More sharing options...
keithk831 Posted December 21, 2010 Share Posted December 21, 2010 Thanks for the input. I will stick with the stock for now. Plus it's a PITA to install. Not worth it if you have an 07. I put an STi up in mine and it made a difference. Link to comment Share on other sites More sharing options...
