My Car Posted December 17, 2010 Share Posted December 17, 2010 Well my head gasket finally gave way and ive got a sputtering hole on the right side of the engine. I'm going to attempt to remove the head and replace the gasket with the engine still in the vehicle. The main question is, can it be done that way? I've heard that it can but at just a glance it looks like the bolts might hit the engine compartment as I try to remove them. It's a 94 Legacy station wagon nonturbo with roughly 250,000 miles. Needing tricks, tips, advice on how to best accomplish this. Any help it appreciated. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted December 18, 2010 I Donated Share Posted December 18, 2010 the head bolts will hit the frame, so you will at least need to undo the motor mounts and lift the engine up some. Personally I don't feel safe working on an engine that is supported by blocks or hanging from a chain so I would rather just take it all the way out and put it on an engine stand. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
My Car Posted December 18, 2010 Author Share Posted December 18, 2010 thanks. Link to comment Share on other sites More sharing options...
certifiednut Posted December 20, 2010 Share Posted December 20, 2010 i did the heads on my 96 2.5 without pulling the motor or taking the motor mounts loose, you just cant get the head bolts out of the head, you need to take them out together Link to comment Share on other sites More sharing options...
GNG_Kirby Posted December 23, 2010 Share Posted December 23, 2010 ^What he said. It is possible, but I like to go through all the seals while I'm doing HG jobs. Might as well if its out infront of you. Oil seperator plate is a MUST if the engine is pulled. New design and only like $35 at Subaru for the new metal plate and screws. Just my 0.02. -Kirby Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted December 25, 2010 Share Posted December 25, 2010 keep the engine in the car, pull the headbolts as much as possible and just pullout the head. It is a pain, but saves alot of energy by pulling the engine, and then you need a hoist/lift. Link to comment Share on other sites More sharing options...
