cas5259 Posted December 16, 2010 Share Posted December 16, 2010 All, I'm in the middle of a timing belt replacement on a 2.5i SOHC. I'm up to the point where I have replaced everything and am ready to put the new belt on. I can get the crank and cams lined up with the belt partially on, but when it comes time to get the belt over the toothed idler on the bottom, there is just no room to slip it on. I've tried a few combinations of removing pulleys, but I never have enough room. Thanks, Chris Link to comment Share on other sites More sharing options...
Osei Posted December 16, 2010 Share Posted December 16, 2010 There is a bolt that goes through the crankcase by the oil pump. Leave the lower crank pulley off. Line up marks, put on pulley so the teeth mesh. Use a long screwdriver and you can fulcrum the pulley in to line up the bolt hole. The bolt will be hard to see when the engine is not out, but feel for it, its there. O. Link to comment Share on other sites More sharing options...
cas5259 Posted December 20, 2010 Author Share Posted December 20, 2010 Thanks Osei, that was easy! Link to comment Share on other sites More sharing options...
Osei Posted December 20, 2010 Share Posted December 20, 2010 That's what the forum is for, to help each other. O. Link to comment Share on other sites More sharing options...
