KU_MechE Posted December 15, 2010 Share Posted December 15, 2010 I'm looking for a winter setup for my car and I don't really need to spend the money on 18" wheels and tires. Plus, on winter roads, I wouldn't mind the extra tire a 17" wheel affords. Has anyone downgraded their Spec.B to a 17" setup and what tire size did you use? Using the 1010Tires.com calculator and the stock size as a comparison, here are my options: Stock 2007 Legacy Spec.B: 215/45R18 Rim Width Range: 7 - 8 in Overall Diameter: 25.61 in 650.49 mm Sidewall Height: 3.80 in 96.52 mm Actual Speed: 60 mph 100 km/h 215/50R17 Rim Width Range: 6 - 7.5 in Overall Diameter: 25.46 in 646.68 mm Sidewall Height: 4.23 in 107.44 mm Speedometer1: 60.3 mph 100. km/h Diameter Difference: 0.59% smaller than stock 215/45R17 (stock 2007 Legacy GT tire size) Rim Width Range: 7 - 8 in Overall Diameter: 24.61 in 625.09 mm Sidewall Height: 3.80 in 96.52 mm Speedometer1: 62.4 mph 104. km/h Diameter Difference: 3.91% smaller than stock 225/45R17 Rim Width Range: 7 - 8.5 in Overall Diameter: 24.97 in 634.23 mm Sidewall Height: 3.98 in 101.09 mm Speedometer1: 61.5 mph 102. km/h Diameter Difference: 2.5% smaller than stock 225/50R17 Rim Width Range: 6 - 8 in Overall Diameter: 25.85 in 656.59 mm Sidewall Height: 4.42 in 112.26 mm Speedometer1: 59.4 mph 99.0 km/h Diameter Difference: 0.93% larger than stock I'm leaning towards the 225/50R17 with plenty of cushion and protection from potholes while also filling up the wheelwell. i'm not concerned about slower acceleration due to increased tire size or the difference in the speedo. Can anyone come up with a reason not to use this tire size? Fitment issues? Rubbing on spring perch? Rubbing on fenders? For Reference, i'm also leaning towards the Drag DR-34 wheels in 17x7.5 et +45 5x100. If not the DR-34, i'l try to find some sock LGT or WRX wheels. Also, how annoying is the TPMS light in the cluster? I'd rather not bother with TPMS in the winter wheels since that's a pretty significant cost. http://i54.tinypic.com/2a9xnd5.jpg Link to comment Share on other sites More sharing options...
KU_MechE Posted December 15, 2010 Author Share Posted December 15, 2010 Here's the tire I'd most likely install: http://i54.tinypic.com/2airm7t.jpg The LGT SB in question: http://i54.tinypic.com/2cngoax.jpg http://i52.tinypic.com/11v3290.jpg and my 1994 Toyota MR2 Turbo for good measure: http://i51.tinypic.com/f9i9fq.jpg http://i53.tinypic.com/a2t7wo.jpg http://i55.tinypic.com/68a6vo.jpg http://i52.tinypic.com/v6qlug.jpg Link to comment Share on other sites More sharing options...
rainman Posted December 15, 2010 Share Posted December 15, 2010 those tires are amazing btw! had them installed this past saturday afternoon when we got 3-4 inches. not much of a snow but no problems whatsoever! Link to comment Share on other sites More sharing options...
KU_MechE Posted December 16, 2010 Author Share Posted December 16, 2010 Can anyone comment on downsizing for winter wheels? Link to comment Share on other sites More sharing options...
BAC5.2 Posted December 16, 2010 Share Posted December 16, 2010 Typically, more sidewall and narrow section width are both good attributes for winter driving. A 205 or 215 would be better than a 225, but you'll be just fine with the 225's. 17's will easily clear your stock brakes, so I don't see any reason why this isn't a fine idea! As for tire size, I know Outback sized tires fit on LGT sedan suspension and they are 225/55/17's. So the 50-series will work fine. Personally, I'd consider the 215/50/17. That's OEM LGT Non-Spec-B sized. No clearance issues, and it'll probably be cheaper than the 225/50. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
rainman Posted December 16, 2010 Share Posted December 16, 2010 1" drop on a LGT with OEM 17" wheels with 215/50/17 here, no problems Link to comment Share on other sites More sharing options...
brilliant sleeper Posted December 16, 2010 Share Posted December 16, 2010 1" drop on a LGT with OEM 17" wheels with 215/50/17 here, no problems same here, but with 225's Link to comment Share on other sites More sharing options...
KU_MechE Posted December 17, 2010 Author Share Posted December 17, 2010 well, today I ordered the 17" Drag DR-34s in gunmetal and some General Altimax Arctic tired in 215/55-17. I'll post pics after they're installed. Link to comment Share on other sites More sharing options...
