roll_tide Posted March 8, 2011 Share Posted March 8, 2011 Ahhh. So it looks like we are both in luck. And why can't you use the Vag-Com cable? Link to comment Share on other sites More sharing options...
sulk Posted March 8, 2011 Share Posted March 8, 2011 How much better is the throttle now it has been re-worked? Much better than stock, although I've been driving with it for a while and dont have a stock one and mine to compare it to recently. Don't really want to flash back to stock either. I am also still technically mid tune, havn't had the time and waiting for better weather to finish it off. Those definitions MAY work for your car, you need to get a cable and download your rom and see if the ECU id is the same as the one posted. If it is then you are good to go, if not, youll have to post it online and wait for it to be defined. Though dschultz has been pretty good lately with them. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 9, 2011 Share Posted March 9, 2011 Yeah that is my plan compare the ECU ID's first but I may just take it to a tuner and do it all in one swoop the first time around Link to comment Share on other sites More sharing options...
GEE-OTTO Posted March 9, 2011 Share Posted March 9, 2011 Ahhh. So it looks like we are both in luck. And why can't you use the Vag-Com cable? 08+ Legacies have a 32 bit ECU unlike the earlier years that have a 16 bit ECU the VAG COM's chip is made to work with a 16 bit ECU the Tactrix 2.0 is made for a 32 bit ECU Link to comment Share on other sites More sharing options...
