SBT Posted December 13, 2010 Share Posted December 13, 2010 You've replaced the fuel filter? Since you're on stands, pull the catalytic converter out of the equation and see what happens. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
amorgan93 Posted December 13, 2010 Author Share Posted December 13, 2010 You've replaced the fuel filter? Since you're on stands, pull the catalytic converter out of the equation and see what happens. run it open header? i cant weld. how would the cat. converter cause it to die randomly? Link to comment Share on other sites More sharing options...
amorgan93 Posted December 13, 2010 Author Share Posted December 13, 2010 You've replaced the fuel filter? Since you're on stands, pull the catalytic converter out of the equation and see what happens. run it open header? i cant weld. how would the cat. converter cause it to die randomly? and yes ive replaced fuel filter fuel pump fuel strainer plugs plug wires crank angle sensor TPS MAF sensor Ignition control module pulled and cleaned IAC thoroughly i'm clueless. also i still have a check engine light after replacing all those, and still no codes are being given. Link to comment Share on other sites More sharing options...
SBT Posted December 13, 2010 Share Posted December 13, 2010 I was hypothesizing that your catalytic converter is heating up and blocking the flow of exhaust gas - hence the suggestion to just take it temporarily out of the equation. If it runs correctly (albeit loudly) then you've isolated it to that part. Any way to make a vid/sound of it running/shutting down? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
amorgan93 Posted December 13, 2010 Author Share Posted December 13, 2010 I was hypothesizing that your catalytic converter is heating up and blocking the flow of exhaust gas - hence the suggestion to just take it temporarily out of the equation. If it runs correctly (albeit loudly) then you've isolated it to that part. Any way to make a vid/sound of it running/shutting down? yeah i will try and make a vid today. i tried once already but my camera shuts off after 3 minutes and there is no way i can turn that timer off. But i have an old samsung camera ill see if i can dig up. And there is no struggle from the motor, no sputtering, noting when it dies. it just cuts off like i turned off the ignition. How do i remove the catalytic converter? is it not welded in place? ive never messed with exhaust before, so what i know is very limited. Link to comment Share on other sites More sharing options...
subikid90 Posted December 13, 2010 Share Posted December 13, 2010 Its bolted to the exhaust manifold, only 2 bolts -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
