.R Geil Posted November 29, 2010 Share Posted November 29, 2010 Hi, Was wondering if anyone knew how much a timing belt and water pump replacement would cost from a shop? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 29, 2010 Share Posted November 29, 2010 Plan on $1000.00 maybe $750 from a independant shop....call one and ask. I spent about $525 on parts alone when I did mine 2 years ago. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AShoe Posted November 29, 2010 Share Posted November 29, 2010 A shop near me quoted 5 hours ($400) for labor. Link to comment Share on other sites More sharing options...
KCwagon Posted November 29, 2010 Share Posted November 29, 2010 $400 would be considered a good deal for labor. $500 is probably closer to average. The cost of parts will vary depending on what you need to replace. You will at least need a new belt (obviously), a new tensioner, and the small pulley next to the tensioner. If the water pump is leaking you will need a new one of those. Fredbeans parts has all the replacement parts you may need in one, nice & neat package. You might check it out. Average range should be $750-$900 depending on shop rate and parts needed. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 29, 2010 Share Posted November 29, 2010 Might as well do the 2 drive belts (PS & Alt) and change the anti-freeze. Thermostat ? It all adds up. May be close to a oil change too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
