amorgan93 Posted November 29, 2010 Share Posted November 29, 2010 should have noticed first thing that my check engine light never comes on, figure the bulb is bad. Doesnt come on during diagnostics, anything. So can someone tell me if there is an easy way to remove the guage cluster, because it appears that the entire dash must come out in order for the guage to come out, and im not up for pulling the dash... thanks a bunch Link to comment Share on other sites More sharing options...
Jeffzguy Posted December 1, 2010 Share Posted December 1, 2010 Its not easy but it isn't near as bad as pulling the dash. You have the pull the steering wheel and then take off the trim around that area and then there are some bolts holding the cluster in. When you take the cluster out be careful pulling the plugs and the speedo cable. I have never pulled the Subi cluster but I've done my Nissan lots of times. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted December 1, 2010 Share Posted December 1, 2010 Someone probably removed it. Link to comment Share on other sites More sharing options...
