jCubed Posted November 25, 2010 Share Posted November 25, 2010 So I just installed the DDMTuning HID kit and I just realized then when the headlights are off and I pull on the high beams to signal I'm passing or if I'm just mad, it flashes the HID low beams as well. Does anyone kow how to fix this since I don't want to flash my HIDs and screw them up. Thanks everyone! You guys are all my best resource for all my Subaru questions and upgrade decisions. Link to comment Share on other sites More sharing options...
laz Posted November 25, 2010 Share Posted November 25, 2010 What year car? X --- Link to comment Share on other sites More sharing options...
jCubed Posted November 25, 2010 Author Share Posted November 25, 2010 2010 3.6R Limited Link to comment Share on other sites More sharing options...
f1anatic Posted November 25, 2010 Share Posted November 25, 2010 So I just installed the DDMTuning HID kit and I just realized then when the headlights are off and I pull on the high beams to signal I'm passing or if I'm just mad, it flashes the HID low beams as well. Does anyone kow how to fix this since I don't want to flash my HIDs and screw them up. Thanks everyone! You guys are all my best resource for all my Subaru questions and upgrade decisions. I have the same problem and it is likely because of the harness. Link to comment Share on other sites More sharing options...
jCubed Posted November 26, 2010 Author Share Posted November 26, 2010 Can someone without HIDs true this and let us know? Link to comment Share on other sites More sharing options...
DarkSlide Posted December 8, 2012 Share Posted December 8, 2012 I heard that the quality of ddmtuning has changed in the past year...ships from different location. I had a set from them a couple years ago and they were great. I noticed these newer ones are cheaper and the ballasts arent as good. Might want to try getting the wiring harness to connect to your battery instead...no wires are crossed? i have seen these ddms on my car and friends car flicker sometimes especially when warming up...i donu if this helps holla Link to comment Share on other sites More sharing options...
3.6rrrrrmatey Posted December 24, 2012 Share Posted December 24, 2012 I am stock and Yes, if your h7 projector is off it will come on with the high beams. I also noticed a small amber bulb behind the amber reflector that doesn't blink with the turn signal? I find that pretty weird. Can't see the turn signal from the side. I'd like to rewire that to blink with the turn signal. Going to suck to replace that amber bulb when it goes out and it's useless. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted December 24, 2012 Share Posted December 24, 2012 I can tell you that on my 08 this is normal behavior. I just don't use the flash to pass unless my lights are already on. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
