TRAC3 Posted November 24, 2010 Share Posted November 24, 2010 So started up the leggy today and thought i heard a "crack" noise or solid metal on metal hit like something shifting in the chassis. Noticed it again on my short drive to the train station on a couple but not all corners while braking. Broken motor mount? Last trip i took it on was through brooklyn and there were some severe potholes or road joints that i couldn't avoid. So something might have been jarred loose or broken. It doesn't sound suspension only because t wasn't consistent on every bump today. Link to comment Share on other sites More sharing options...
TRAC3 Posted November 24, 2010 Author Share Posted November 24, 2010 thought this was fairly straightforward question, no one has an opinion, no one has had a similar issue of something breaking in the chassis? Link to comment Share on other sites More sharing options...
Max Capacity Posted November 24, 2010 Share Posted November 24, 2010 Not enough info. I guess it steers and drives ok. Is it still doing the noise ? can you feel movement in the shifter when you rev the engine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
