awd Posted November 13, 2010 Share Posted November 13, 2010 I have an 08 2.5 limited and want to improve the sound of the stock system without replacing the h/u. If I upgrade all the speakers, add a sub and a good amp will that improve the stock system enough to sound decent? Not looking for a competition system or anything, just something that sounds more full and balanced.. Link to comment Share on other sites More sharing options...
OutbackXT05 Posted November 13, 2010 Share Posted November 13, 2010 Well I just added a woofer/amp and it does sound decent in my 05. If your adding new speakers in the doors id throw in a 4 channel amp even if its a cheap one because it will sound 10 times better than the stock H/U Link to comment Share on other sites More sharing options...
awd Posted November 13, 2010 Author Share Posted November 13, 2010 Thanks, I was planning on adding a 4 channel amp as well as replacing the door speakers and adding a subwoofer, just want to make sure it would make enough of an improvement to justify the cost.. I will wait for others to chime in with opinions.. Link to comment Share on other sites More sharing options...
RJS5689 Posted November 14, 2010 Share Posted November 14, 2010 I'm running four Alpine Type-S powered by a 4-channel amp, and a 12" sub powered by a monoblock amp. I'm also utilizing the stock headunit. You will need line output converters because we do not have pre-amp outs on the Legacy head. The system sounds much better than stock, but I plan to do more work in the future. If I could do it again I wouldn't use the standard, cheap LOC. I would splurge on one of the electronic units. Link to comment Share on other sites More sharing options...
mwiener2 Posted November 14, 2010 Share Posted November 14, 2010 Cleansweep My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
RJS5689 Posted November 14, 2010 Share Posted November 14, 2010 Cleansweep Yep, it would have been the smarter option for sure. OP: Consider the Cleamsweep if you plan to do speakers, subs and amps. Link to comment Share on other sites More sharing options...
awd Posted November 14, 2010 Author Share Posted November 14, 2010 Thanks, I will do a search on the cleansweep mod before I do anything.. Man, I just checked out the carpc thread and if the jdm cubby would work that would be tempting. Anybody know of a shallow mount touch screen head unit that you might be able to mount in the cubby area without hacking it up to fit a full double din in there? Does Kenwood, Alpine or any manufacturer make anything like that? Is there any somewhat simple way to get a clean install in the cubby? Link to comment Share on other sites More sharing options...
