jamesm113 Posted November 1, 2010 Share Posted November 1, 2010 How does one reset OBDII codes? I've tried pulling the battery for a few minutes, but P0400 keeps showing up on my scanguage, but the CEL hasn't come on again. Thanks! Link to comment Share on other sites More sharing options...
Zues Marine Posted November 1, 2010 Share Posted November 1, 2010 you can clear the codes with the scangauge.. but theyll just come back until you fix the problem Link to comment Share on other sites More sharing options...
ehsnils Posted November 1, 2010 Share Posted November 1, 2010 And the P0400 is the EGR malfunctioning. It's probably filled with soot (or the pipe leading to it is). Way to common problem. One of those "features" that we really don't want. But at least it isn't causing any technical problems - it's just an emissions issue. Link to comment Share on other sites More sharing options...
jamesm113 Posted November 1, 2010 Author Share Posted November 1, 2010 Yea, I figured out the issue - the backpressure transducer (or vacuum modulator, depending on where you look) is bad (doesn't hold a vacuum on the bottom port). The new part is on the way, but since the CEL isn't coming on anymore, i'd like to clear the codes - the scanguage's clear doesn't seem to be working that well - the code just comes back up after I do a code scan again. Gotta pass smog by the 20th. Link to comment Share on other sites More sharing options...
