carnumber19 Posted October 28, 2010 Share Posted October 28, 2010 I have a 95 Legacy L with the 5 speed. I have my brother swapping out the throwout bearing in the trans this weekend and while its up on his lift I figure I'll have him replace the differential fluid as well. I'm pretty sure its all 75w90 for the trans, mid diff, and rear diff, correct? If so, how much for each? I think I read it was 4 quarts for the trans but not sure about the rest. Link to comment Share on other sites More sharing options...
carnumber19 Posted October 28, 2010 Author Share Posted October 28, 2010 Also, any problems running synthetic in the differentials? I'd like to go full synthetic everywhere, but not sure if the reduced friction will be a problem on the clutch discs. Link to comment Share on other sites More sharing options...
Osei Posted October 29, 2010 Share Posted October 29, 2010 No problem in running synthetics. Just drain as much of old stuff out as possible. Gear changes are slicker. Should not be a major difference if any in capacities for 5mt. Front is 3.7 quarts. Just put in 3 and check your dipstick as you add. Rear is .8 qt. just drain from lower hole. Replace plug putting sealant on threads and fill through top hole until fluid just starts to come out or you can just put your finger in and when you can feel liquid, stop. Buy a manual. O. Link to comment Share on other sites More sharing options...
Bannonjr Posted October 29, 2010 Share Posted October 29, 2010 I run amsoil's 75w90 SVG in the tranny and rear...works great! Really reduced the chug in the tranny, especially in the winter..and no more gear whine. Link to comment Share on other sites More sharing options...
