Redline2083 Posted October 27, 2010 Share Posted October 27, 2010 I want to buy a wide band. Which is the better setup? The analog or digital display? Link to comment Share on other sites More sharing options...
Th3Franz Posted October 27, 2010 Share Posted October 27, 2010 I like digital displays for AFR. You can see the precise number it's hitting at WOT -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted October 27, 2010 Share Posted October 27, 2010 The analog display model does not have a serial output so you won't be able to easily log data with it. It does have a 0-5v signal but the usual Subaru logging software (AP RaceTuner, opensource stuff) doesn't work with that. Having used both of them, I can say that I actually liked the analog display more than I thought I would. There are zero refresh rate issues--the needle moves smoothly and you don't miss any possible "hiccups." On the search for a new DD... Link to comment Share on other sites More sharing options...
Redline2083 Posted November 6, 2010 Author Share Posted November 6, 2010 Thanks guys, i got the digital wideband Link to comment Share on other sites More sharing options...
