Baddog Posted October 25, 2010 Share Posted October 25, 2010 What is needed to put in a wheel from an 02-03 WRX and do 04 STI springs fit on the Non-STI 04 WRX Struts? Link to comment Share on other sites More sharing options...
Zues Marine Posted October 25, 2010 Share Posted October 25, 2010 steering wheel? Link to comment Share on other sites More sharing options...
Baddog Posted October 25, 2010 Author Share Posted October 25, 2010 Yeah. Woops Link to comment Share on other sites More sharing options...
subikid90 Posted October 25, 2010 Share Posted October 25, 2010 You can use your leggy struts but need 04 sti tophats -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Zues Marine Posted October 25, 2010 Share Posted October 25, 2010 for the steering wheel..You will need a T30 Torx bit, a 10mm socket, a 17mm socket, and a small flat blade screwdriver to get the job done Link to comment Share on other sites More sharing options...
Baddog Posted October 25, 2010 Author Share Posted October 25, 2010 You can use your leggy struts but need 04 sti tophats I currently have 04 WRX Springs and Struts on the car. The front top hats are from the WRX and the rears are from the legacy. Link to comment Share on other sites More sharing options...
Baddog Posted October 25, 2010 Author Share Posted October 25, 2010 for the steering wheel..You will need a T30 Torx bit, a 10mm socket, a 17mm socket, and a small flat blade screwdriver to get the job done Awesome. So basically it's a direct swap? Link to comment Share on other sites More sharing options...
Zues Marine Posted October 25, 2010 Share Posted October 25, 2010 yeah, there's a phase 2 type plug in some of the later legacys that use less power to the airbags which is the plug for the wrx, its aup in the air as far as being able to tell which cars have and dont have that plug Link to comment Share on other sites More sharing options...
Baddog Posted October 25, 2010 Author Share Posted October 25, 2010 Well shiet I may need to do some more research on that. Link to comment Share on other sites More sharing options...
Baddog Posted October 25, 2010 Author Share Posted October 25, 2010 Well to clear this up I believe I found out in 98 is when they changed to the lower power plug. So I am gonna say it's a no go. Link to comment Share on other sites More sharing options...
Zues Marine Posted October 25, 2010 Share Posted October 25, 2010 you can splice the plugs if youre ballsy enough Link to comment Share on other sites More sharing options...
Baddog Posted October 25, 2010 Author Share Posted October 25, 2010 How about if I get this wheel YOU can do it ha Link to comment Share on other sites More sharing options...
Zues Marine Posted October 25, 2010 Share Posted October 25, 2010 i couldnt get my wheel off my car back before i sold the jdm wrx one that i had, lol Link to comment Share on other sites More sharing options...
Baddog Posted October 25, 2010 Author Share Posted October 25, 2010 i couldnt get my wheel off my car back before i sold the jdm wrx one that i had, lol Hmm I guess they say you can swap the charges over. I will see how much he wants for the wheel first. http://www.subaruforester.org/vbulletin/f77/my03-wrx-steering-wheel-installed-airbag-charge-swap-42790/ Link to comment Share on other sites More sharing options...
