mtenhoven Posted May 4, 2005 Share Posted May 4, 2005 I installed the factory subwoofer ('05 Baja) last night and noticed this morning when starting the car I'm getting a "thump" from the subwoofer. Is this normal during turn on? Link to comment Share on other sites More sharing options...
rony Posted May 4, 2005 Share Posted May 4, 2005 Nope, don't have that problem. I would suggest checking the connections on the sub and headunit. Other than that, you might have a faulty sub? My Car vBGarage Link to comment Share on other sites More sharing options...
gfxdave99 Posted May 4, 2005 Share Posted May 4, 2005 I installed the factory subwoofer ('05 Baja) last night and noticed this morning when starting the car I'm getting a "thump" from the subwoofer. Is this normal during turn on? Is it a single thump when it turns on or like a extended thumping sound? If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
DSattler Posted May 4, 2005 Share Posted May 4, 2005 No "extra" sounds from my sub, at turn-on or otherwise. Link to comment Share on other sites More sharing options...
mtenhoven Posted May 4, 2005 Author Share Posted May 4, 2005 It's a single thump. If I remember correctly, it occurs when the key is turned from the On to the Start position. Link to comment Share on other sites More sharing options...
gfxdave99 Posted May 4, 2005 Share Posted May 4, 2005 It's a single thump. If I remember correctly, it occurs when the key is turned from the On to the Start position. I wouldnt worry about it then.. I mean it should mute itself when it first turns on so that you dont get the thump, but if it doesnt annoy you too much I'd just let it go If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
