Jeffzguy Posted October 6, 2010 Share Posted October 6, 2010 So my crank pulley has started to wobble and squeak, well I am curious both how this happened and if the solution is just a new pulley? Link to comment Share on other sites More sharing options...
Bdubs Posted October 6, 2010 Share Posted October 6, 2010 The wobble is common. A new one may help you, as long as the shaft on the crank itself hasn't been destroyed thanks to the wobble. Also, torque specs on repair manuals were incorrect, resulting in ruined cranks, sheared keyways, etc. Link to comment Share on other sites More sharing options...
Jeffzguy Posted October 6, 2010 Author Share Posted October 6, 2010 What is correct then? Link to comment Share on other sites More sharing options...
Bdubs Posted October 7, 2010 Share Posted October 7, 2010 If you can get it to around 140-150 ft lbs, that's about where you want to be. Link to comment Share on other sites More sharing options...
Jeffzguy Posted October 7, 2010 Author Share Posted October 7, 2010 Now where do I get a new pulley? Link to comment Share on other sites More sharing options...
Legacy Wagon Posted October 8, 2010 Share Posted October 8, 2010 Junk yard. It depends if your key on the crankshaft is ruined. You'll need to pull off that gear that is behind the crank pulley and check to see if that key is twisted or missing or possibly eating into your crank pulley. If the key's destroyed you should get one of those too. It looks like a half moon sticking out of your crankshaft. Link to comment Share on other sites More sharing options...
Jeffzguy Posted October 8, 2010 Author Share Posted October 8, 2010 Oh, just sent that PM before I read this, I can call my crappy junk yard where I can't pull myself. Link to comment Share on other sites More sharing options...
Legacy Wagon Posted October 10, 2010 Share Posted October 10, 2010 Yeah, but tell them to get you that gear behind the pulley and the key just in case then. Link to comment Share on other sites More sharing options...
