Mobius1 Posted October 4, 2010 Share Posted October 4, 2010 I have the 2.2 Legacy, just the other day it started idling funny, before it would always idle below 1,000 RPM and always drop there instantly after pushing in the clutch. But now when I push the clutch in the RPM slowly drop to about 1,600 RPM and drop down to about 1,200 RPM once the vehicle comes to a complete stop, or very close to not moving at all. It does not matter if I'm going 50 and coast to a stop in nuetral, or if I push the clutch in while in traffic, the RPM'S sit at 1,500 until I'm bassically stopped, then they drop to about 1,200 which is still higher then what it used to idle at. I'm not sure what the problem is since I've never beat on the car, always drive it the same way, even changed all the fluids recently. Any insight would be much appriciated, thanks Link to comment Share on other sites More sharing options...
98quiksilvergt Posted October 4, 2010 Share Posted October 4, 2010 Check for vacuum leaks. That's most likely the problem. Link to comment Share on other sites More sharing options...
Platinum_Racing Posted October 4, 2010 Share Posted October 4, 2010 +1 And clean the idle air control solenoid too. Link to comment Share on other sites More sharing options...
Mobius1 Posted October 6, 2010 Author Share Posted October 6, 2010 I see. This may be a stupid question, but are there any common places to look for leaks on this engine? thanks Link to comment Share on other sites More sharing options...
subikid90 Posted October 6, 2010 Share Posted October 6, 2010 Not really. I had problems where the vac lines connect to metal nipples. It cost me like 12 bucks, about 11ft, or vac line to replace it all. If the lines are crusty just replace them, only take one off at a time though because you will start to get them mixed up lol -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
