Deadleave Posted October 1, 2010 Share Posted October 1, 2010 I am about to drill a hole in the back of the car for a back up cam. Sucker is big, but flush mount, (1.25" diameter and 2" depth). I am trying figure out where it would be less damaging to install. I could go into bumper skin "B" , or trunk lid "A", or bottom diffuser "C" Just not sure which area will be easiest to fit the cam, which requires the least amount of damage to car. (I know I am drilling a hole). Thanks for any tips Link to comment Share on other sites More sharing options...
SVXdc Posted October 2, 2010 Share Posted October 2, 2010 I'd think C would get dirty faster. Test your camera in the rear camera input that you'll actually be using before you run the wires or drill holes. People have bought cameras that didn't work with the OEM Navi (but didn't realize it until after they had drilled, cut, glued, etc.). Link to comment Share on other sites More sharing options...
Drift Motion Posted October 2, 2010 Share Posted October 2, 2010 ^ very good point! And since most OEM camera is mounted near the plates on the trunk, I'd think that would be a very good location. Link to comment Share on other sites More sharing options...
Deadleave Posted October 2, 2010 Author Share Posted October 2, 2010 I have a custom setup for carpc, and tested the aux input on my lilliput, so the camera is good to go. I'm leaning towards "A" , just wasn't sure how many layers of metal I'd be drilling through. Thanks and good point about it getting dirty. Link to comment Share on other sites More sharing options...
jton Posted October 2, 2010 Share Posted October 2, 2010 a. you can remove/replace that section of the trunk lid - without buying a whole new trunk. would make it easier to work on too Link to comment Share on other sites More sharing options...
Deadleave Posted October 3, 2010 Author Share Posted October 3, 2010 jton; Thanks, that helps a lot, glad I wont have to replace the whole trunk if it goes south Link to comment Share on other sites More sharing options...
Vsick Posted October 5, 2010 Share Posted October 5, 2010 Hi Dead, which camera did you go with? Does your lilliput automatically switch to aux in when you pop it into reverse? Link to comment Share on other sites More sharing options...
Deadleave Posted October 6, 2010 Author Share Posted October 6, 2010 http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270291430692&viewitem=&sspagename=STRK%3AMEWNX%3AIT this is the cam I got, if you don't need the IR, you can get a cheaper CCD, that is also much smaller footprint. NIght vision is actually very very good on this, and image is sharp from the CCD chip. Lilliput i have 669 and has a aux input wire, 12v off the reverse wire, send it to video 2. So its all automatic. Hope that helps Link to comment Share on other sites More sharing options...
