docdrey Posted October 1, 2010 Share Posted October 1, 2010 Hey guys is the spec b tranny and diff the same as the 05-07 sti? the reason i ask is because i found totaled spec b and a sti with no drive-train but the motor is there. wanted to make one car out of two. please help? Link to comment Share on other sites More sharing options...
RJS5689 Posted October 1, 2010 Share Posted October 1, 2010 The rear diff in the SpecB and STI are both a Torsen R180. You can use the same transmission components as long as they are paired correctly. The flywheel is larger and heavier in the SpecB, therefore it won't work when paired with a smaller STI clutch and pressure plate. You can, however, use STI/SpecB components in the same housing when paired correctly. I run an STI clutch, pressure plate and flywheel in my SpecB. For your application you'd probably prefer the STI components. The STI flywheel is lighter and smaller. Link to comment Share on other sites More sharing options...
SCSpecB Posted October 1, 2010 Share Posted October 1, 2010 ^Hmmm....I think this would be a good option for me here in the near future.... Link to comment Share on other sites More sharing options...
Draco-REX Posted October 1, 2010 Share Posted October 1, 2010 If you use a spec.B 6mt, you'll have the same gearing as an 07+ STI except for 6th which will be taller. Not a bad setup. I do not, however, know if the spec.B gearset will be as durable. Link to comment Share on other sites More sharing options...
Kylar Posted October 1, 2010 Share Posted October 1, 2010 lets not forget the spec b 6 spd doesnt have the LSD front diff or the DCCD Link to comment Share on other sites More sharing options...
awwsheeet Posted October 1, 2010 Share Posted October 1, 2010 since you guys know so much about the tranny and diff. what gear oil should i use and what brand? is it the same for both the trans and the rear? and whats the service intervals? Link to comment Share on other sites More sharing options...
LuckyBob Posted October 1, 2010 Share Posted October 1, 2010 I've heard (via NSFW's 6 speed swap thread) that the Spec.B R180 rear diff has a R160 input yoke, which indicates that it would be different than the STI part. Then again, if you're getting the tranny, diff, and driveshaft out of the Spec.B they'd all mate together just fine. Link to comment Share on other sites More sharing options...
docdrey Posted October 2, 2010 Author Share Posted October 2, 2010 wow you guys are really knowledgeable! thanks! Link to comment Share on other sites More sharing options...
Draco-REX Posted October 2, 2010 Share Posted October 2, 2010 If this will be a daily driver with maybe the occasional AutoX or RallyX, Subaru Extra-S is probably the best for you. If you plan to make this a dedicated track car or competitive AutoX/RallyX car, you'll want something that can hold up to the heat better. In that case, I'd recommend Motul or Amsoil. Link to comment Share on other sites More sharing options...
Strizzy Posted October 2, 2010 Share Posted October 2, 2010 After switching to Motul gear oil, my low speed shifts to 1st have been extremely easier, and overall shifting is smoother. This is also with an STI Exedy clutch, lightweight flywheel and STI front LSD. My bad luck build Link to comment Share on other sites More sharing options...
