babybaluga32 Posted September 29, 2010 Share Posted September 29, 2010 I bought a chinese fuel pump for a wrx on ebay (stupid idea).. I Installed it a couple weeks ago and have had a the same problem a couple times. Today my car was close to WOT turning up a slow 90 degree "onramp". I made it about half way up and my engine started dropping rpms and then picking up again, but come the top it died completely. After turning it over a couple times on flat ground it started again and drove fine.. I took the pump out a couple of days ago and saw that there is a hole that releases gas out of the bottom of them pump, It was covered up by the rubber "Pump holder". I cut the rubber and gave it room to escape back into the tank.... I thought that would fix it but after today i guess it hasnt. Any suggestion would be greatly appreciated!! http://cgi.ebay.com/ebaymotors/Fuel-Pump-Subaru-WRX-Impreza-_W0QQcmdZViewItemQQhashZitem3f0350a689QQitemZ270638556809QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_1847wt_941 Link to comment Share on other sites More sharing options...
rshaw123 Posted September 29, 2010 Share Posted September 29, 2010 get rid of the pump and buy an OEM one Link to comment Share on other sites More sharing options...
bluesuby Posted September 30, 2010 Share Posted September 30, 2010 Chinese products....out to kill us one by one. Link to comment Share on other sites More sharing options...
laz Posted September 30, 2010 Share Posted September 30, 2010 get rid of the pump and buy an oem one +1 x --- Link to comment Share on other sites More sharing options...
98quiksilvergt Posted September 30, 2010 Share Posted September 30, 2010 Is the fuel strainer shorter than the factory one? That will cause it run out of gas sooner. I had one of those too. It lasted about two months. The strainer that came with it was completely wrong. It went sideways off the bottom of the pump. The factory one goes strait down. Link to comment Share on other sites More sharing options...
babybaluga32 Posted September 30, 2010 Author Share Posted September 30, 2010 The new pump "strainer" is flat vs. 45degree downward of stock. Theres hardly a differance.. At least not so much that it wouldnt be able to suck up gas .. It does run out of gas sooner around a quarter tank. When what i described above happened it was around half a tank. I doubt the gas could have been pulled to the back so far that it starved the pump, which hangs so low in the tank... Maybe im wrong.. Is that possible? Link to comment Share on other sites More sharing options...
Reuben Posted September 30, 2010 Share Posted September 30, 2010 You get what you pay for. When will people learn this! I just had a rant about aftermarket water pumps on another forum last night... Link to comment Share on other sites More sharing options...
98quiksilvergt Posted October 1, 2010 Share Posted October 1, 2010 That's what was happening to mine. It's enough to make the difference. Change that strainer and you won't run out of gas when you turn right. Link to comment Share on other sites More sharing options...
Reuben Posted October 1, 2010 Share Posted October 1, 2010 Also, BG's don't fuel surge till they are practically empty, so babybaluga, i suspect you're dead right in saying it shouldn't happen round half a tank. Link to comment Share on other sites More sharing options...
98quiksilvergt Posted October 1, 2010 Share Posted October 1, 2010 It does. Change the strainer and it won't happen again. I bet you run completely out of gas just under 1/4 tank too. Link to comment Share on other sites More sharing options...
Reuben Posted October 1, 2010 Share Posted October 1, 2010 Interesting note, i have a walbro in my car, i was told by multiple people to use the factory strainer on it, rather than the supplied walbro one. And this is a proper pump manufactuer! Just to back up what quicksilver is saying. Link to comment Share on other sites More sharing options...
babybaluga32 Posted October 1, 2010 Author Share Posted October 1, 2010 Thanks 98quiksilvergt!.. I put my stock back in but i guess ill swap it out and try cheap pump with the factory strainer. Link to comment Share on other sites More sharing options...
98quiksilvergt Posted October 1, 2010 Share Posted October 1, 2010 No problem. I went with a Bosch pump from advance auto. The eBay pump died after about 2 months. Link to comment Share on other sites More sharing options...
