1-3-2-4 Posted September 23, 2010 Share Posted September 23, 2010 I picked up the gasket from the dealer today I know where it is but I haven't tried to remove it are the bolts a pain to get to? Link to comment Share on other sites More sharing options...
Baddog Posted September 23, 2010 Share Posted September 23, 2010 Curious about this as well because I want to do it along with other matainence. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 24, 2010 Author Share Posted September 24, 2010 I went ahead and did this (the IAC in in front of me now) it's not that hard but be warned some coolant will puke out of the lines to the IAC (did not see this on any other sites. I used carb spray and I cleaned out the hoses and I used about the rest of the can for the IAC.. the hoses alone had a lot of crap in it. make sure you take off the top part that you plug in the connector to so you can rotate the shutter and when you clean it make sure it moves freely without any resistance. http://img.photobucket.com/albums/v77/SubaruWRX/IMAG0304.jpg haynes says at operating temp remove the IAC and make sure the shutter is closed like this http://img.photobucket.com/albums/v77/SubaruWRX/IMAG0308.jpg mine looked like this but I did not remove at operating temp due to the coolant lines I knew that would spill. http://img.photobucket.com/albums/v77/SubaruWRX/IMAG0305.jpg Link to comment Share on other sites More sharing options...
Colando Dunes Posted September 25, 2010 Share Posted September 25, 2010 if you don't feel like removing the whole thing you can remove the hose coming off the bottom of your intake just after the maf and spray some cleaner in there. i had this problem where the iac would get stuck open and cause some crazy rpms during idle. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 25, 2010 Author Share Posted September 25, 2010 I tried that way before it did not help at all and I'm happy that I removed it. You can see here how the cleaning helped on a warm start. Aug 28th 2009 [ame=http://www.youtube.com/watch?v=rbCYcWvPWms]YouTube - Warm start[/ame] Sept 24th 2010 [ame=http://www.youtube.com/watch?v=drcrw0ZekiI]YouTube - Clean IAC[/ame] Link to comment Share on other sites More sharing options...
