elib Posted September 19, 2010 Share Posted September 19, 2010 This morning I had to pull out into heavy traffic so I did a 5K clutch dump and later I noticed that my AP said I had hit 16.7psi boost! I've never seen it above 15.4psi before since I got the AP and went stage 1, cobb OTS ACN stage 1 map. It's a otherwise stock spec.B. Is this normal? Should I be worried? I tried to search on this but couldn't find anything relevant. Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 19, 2010 Share Posted September 19, 2010 Mine's done it a few times, but after I was stage-1 for a while, it stopped spiking that high. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
davey smalls Posted September 19, 2010 Share Posted September 19, 2010 is there an aftermarket downpipe on yer car? did your overboost throw a CEL?? Link to comment Share on other sites More sharing options...
elib Posted September 19, 2010 Author Share Posted September 19, 2010 No CEL, stage 1, totally stock except for the AP. I've been stage 1 for a month or two already. Should I only worry about overboost if it throws a CEL? Link to comment Share on other sites More sharing options...
dmanaenk Posted September 19, 2010 Share Posted September 19, 2010 Unless you clamp bpv hoses and a couple of others - that kind of boost won't last by itself. Some hose will either be blown off, or back out enough. And boost leaks can cause some other bad stuff. 666 Link to comment Share on other sites More sharing options...
elib Posted September 19, 2010 Author Share Posted September 19, 2010 So, if this is something to be concerned about what do I do to fix it/diagnose the root cause? I also have a racing catted DP on the way, hopefully will install it next weekend. Will going stage 2 make this worse or possibly fix it? Link to comment Share on other sites More sharing options...
wpmarky Posted September 22, 2010 Share Posted September 22, 2010 Hey Eli, I wouldn't worry about a 1 time boost spike, especially when you did a 5k dump. Stage 2 will set higher boost targets. When you have your car lifted, just check all the tubes to make sure nothing is loose. And log from 2k-7k. A couple runs should tell you whether or not things are ok. Link to comment Share on other sites More sharing options...
