Canyonero Posted September 18, 2010 Share Posted September 18, 2010 im trying to change my transmission with 80-90. but i cant figure out where i drain from and where i fill from... there are 3 10mm drain plugs in a row top to bottom. which is the drain for the trans? also can i fill the trans from the top where the dipstick thats says diff is? Link to comment Share on other sites More sharing options...
Platinum_Racing Posted September 19, 2010 Share Posted September 19, 2010 So I assume 80-90 means GL5 80W90 fluid, which would make this a manual transmission. Then again, it could also mean its an automatic and you just want to change the front differential fluid. Regardless of what transmission you have, you cannot fill the transmission through the diff. The plug for the front diff should be a 21MM bolt right behind the oil pan. Clarification would be appreciated. Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 19, 2010 Share Posted September 19, 2010 It's a manual trans. The 3 10mm plugs are the ball-detent keepers for the shift rods. DON'T REMOVE THEM! The drain plug is right behind the oil pan on the BOTTOM of the transmission. You fill the transmission through the dipstick tube. That's on the passenger side, and is marked by a yellow dipstick. Pull the dipstick out, use a long funnel, and fill the transmission. I like to fill the trans, then idle the car for a little bit. Wait, check the fluid and repeat. I also MUCH prefer to use 2 quarts of Redline Lightweight Shockproof and 2 quarts of Motul 75W90 (Gear300). It's a combination that's served me well for YEARS, and I can downshift into first gear at 25mph if I want to. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Canyonero Posted September 20, 2010 Author Share Posted September 20, 2010 oh shit!!! i removed the 3 bolts on the side but they are back in place and havent caused a problem! Im sorry for not being clear. yes its a manual transmission. found the filler. thanks guys!!!!! Link to comment Share on other sites More sharing options...
