supafla777 Posted September 17, 2010 Share Posted September 17, 2010 Am getting some work done to my 2005 5eat lgt gradually but need some guidance. existing mods is catback exhaust and CAI.what am doing is up pipe down pipe. FMIC with hks bov and boost oil pressure and trans temp gauge. what i need help with is where can i tap into to install trans temp gaugei have installed the up pipe and down pipe. this monday i will be doing the FMIC with hks BOV. am using APV1 to tune the car i have 2 maps stage 1 and stage 2. my question is i need a car for the weekend with just the dp and up pipe done to it can i drive the car without tuning it and finishing the work or not or do i need to at least throw in the stage 1 map. thanks Link to comment Share on other sites More sharing options...
moncur_6 Posted September 17, 2010 Share Posted September 17, 2010 You can drive it, just don't push the revs at all. Link to comment Share on other sites More sharing options...
Strizzy Posted September 17, 2010 Share Posted September 17, 2010 You said you have a stage 2 tune, so flash that map and you'll be good to go, since you already have the UP and DP installed. My bad luck build Link to comment Share on other sites More sharing options...
supafla777 Posted September 17, 2010 Author Share Posted September 17, 2010 thanks strizzy appreciate the info what about the mounting spot for the trans temp gauge. where can i tap into in order to install the trans temp sensor Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted September 17, 2010 Share Posted September 17, 2010 You can Tee into the cooler output line, or you can get an M18x1.5 to 1/8npt adapter and put it in the trans drain plug. I say first option is better, some say second option is better. I'm going to do both... [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
supafla777 Posted September 17, 2010 Author Share Posted September 17, 2010 thnaks climber you guys are a life saver Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted September 17, 2010 Share Posted September 17, 2010 thnaks climber you guys are a life saver I'm having a good say, so http://www.jegs.com/i/JEGS/555/15270/10002/-1 http://prosportgauges.com/subaru-oil-galley-plug.aspx Enjoy [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
BL_Soldier Posted September 17, 2010 Share Posted September 17, 2010 I'd trade in that AP1 for the AP2 using cobbs trade in program. AP1 turned my ECU into a paperweight when I went to get a tune done. AP2 does more and is much smaller. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted September 17, 2010 Share Posted September 17, 2010 AP1 turned my ECU into a paperweight when I went to get a tune done That's probably more a Cobb software bug issue than an AP1 vs AP2 issue. Either way an incredibly rare occurrence. The wonder is he could get ECU access for very little money, with great transparency, or get a Cobb APv2 for the same money, and achieve the opposite... Or do nothing and be perfectly fine... [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Johnnyc192 Posted September 18, 2010 Share Posted September 18, 2010 Dude, goe with Cobb 1 and then Cobb 2 ... do the do... dont do otherwise. It would do damage. I would like 2 see it though on a DYNO> Link to comment Share on other sites More sharing options...
Johnnyc192 Posted September 18, 2010 Share Posted September 18, 2010 I have went Cobb 1 and now I am doing Cobb 2 (perrin) as my car permits(Down pipes, ups too, and intakes), (got me a wagon!) I would like to think it does well, I do 93 octane, any idea on the 1/4 before I a run it? without the wheel in the back, I want to make it weigh less.... other ideas? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted September 18, 2010 Share Posted September 18, 2010 A proper pro tune will do more for you than weight reduction [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
BL_Soldier Posted September 18, 2010 Share Posted September 18, 2010 Well something was rattling around in the apv1. Maybe it was the determining factor for my ecu bricking. I do like the AP2 tho either way. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted September 19, 2010 Share Posted September 19, 2010 Well something was rattling around in the apv1. Maybe it was the determining factor for my ecu bricking. If you heard something rattling around in your engine, would you keep driving? [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Strizzy Posted September 19, 2010 Share Posted September 19, 2010 If you heard something rattling around in your engine, would you keep driving? I currently am... But that's just because I have a new motor going in next week... My bad luck build Link to comment Share on other sites More sharing options...
end0 Posted September 19, 2010 Share Posted September 19, 2010 If you heard something rattling around in your engine, would you keep driving? He's saying something was rattling around in the AP. Link to comment Share on other sites More sharing options...
Strizzy Posted September 19, 2010 Share Posted September 19, 2010 ^It's a metaphor for which he is trying to make a point... My bad luck build Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted September 19, 2010 Share Posted September 19, 2010 I currently am... But that's just because I have a new motor going in next week... Hope you have new pan, oil cooler, heads, turbo, etc also in case the problem (if there is a problem) develops. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Strizzy Posted September 19, 2010 Share Posted September 19, 2010 ^Complete drop-in build and new 20g. I'll have to check with the oil cooler though... My bad luck build Link to comment Share on other sites More sharing options...
BL_Soldier Posted September 19, 2010 Share Posted September 19, 2010 Actually, I hear more than a fair share of rattles with my car. Five years old, 101k and I only got to put a couple thousand on her. I drive in paranoia daily. But I do the upkeep. Fluids, belts, tire rotations, and add upgrades when finances allow for it. Link to comment Share on other sites More sharing options...
Johnnyc192 Posted September 25, 2010 Share Posted September 25, 2010 Found out.... T'was a cheap windshield replacement... years ago during hail damage before the new insurance. I hate that thing, it seals but still. It makes noise. I think I mght be able to get a new one from PPG glass. (Lets hope to have it put in with a guy that has 2 eyes this time. !!!) Link to comment Share on other sites More sharing options...
