frkkevin Posted September 12, 2010 Share Posted September 12, 2010 Ok I've still yet to figure this out. My wife's 95 legacy has no dash lights working.. this is the cluster and hvac controls. The fuse is fine. I've been reading on this subject and others have had this issue but I've never seen a cause or fix. Anyone have any ideas? 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 12, 2010 I Donated Share Posted September 12, 2010 I had the same problem and it took me FOREVER to figure it out. Behind the radio, there should be a yellow wire. Its a ground wire for the lights. If you have an aftermarket radio, whoever put the radio in probably cut the wire. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
frkkevin Posted September 12, 2010 Author Share Posted September 12, 2010 I had the same problem and it took me FOREVER to figure it out. Behind the radio, there should be a yellow wire. Its a ground wire for the lights. If you have an aftermarket radio, whoever put the radio in probably cut the wire. I'll have to look for this wire. When we bought it there was the oem radio in it but there is no telling that could be it. 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
subikid90 Posted September 12, 2010 Share Posted September 12, 2010 you may need new bulbs. There is a few DIY on how to replace them. You can get them all from superbrightleds.com -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
frkkevin Posted September 12, 2010 Author Share Posted September 12, 2010 you may need new bulbs. There is a few DIY on how to replace them. You can get them all from superbrightleds.com I don't think every single bulb would be out at the same time 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
subikid90 Posted September 12, 2010 Share Posted September 12, 2010 In the HVAC I wouldn't be surprised, both my legacys had them blown when I bought them. You might also have a bad dimmer switch. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
frkkevin Posted September 13, 2010 Author Share Posted September 13, 2010 In the HVAC I wouldn't be surprised, both my legacys had them blown when I bought them. You might also have a bad dimmer switch. This is what I was thinking.. but I would hate to replace that whole arm assembly if that wasn't the problem. Is there a way to test the dimmer without removing it? I tested the illumination box under the dash on the panel and it showed it had 13v 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 13, 2010 I Donated Share Posted September 13, 2010 Mine has a bad dimmer switch, I just can't dim them. They will come on though with a bad switch (at least in my case). I would lean more towards a wiring thing. With cars that are this old, there is no telling what people have done to the electricals over the years. And one blown bulb is reasonable, but every last one of them is kinda far fetched. There are 10 or 15 bulbs on the back of our gauge clusters. More times then not they will last the life of the vehicle. I have never once had a dash light blow out on me. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
frkkevin Posted September 13, 2010 Author Share Posted September 13, 2010 Mine has a bad dimmer switch, I just can't dim them. They will come on though with a bad switch (at least in my case). I would lean more towards a wiring thing. With cars that are this old, there is no telling what people have done to the electricals over the years. And one blown bulb is reasonable, but every last one of them is kinda far fetched. There are 10 or 15 bulbs on the back of our gauge clusters. More times then not they will last the life of the vehicle. I have never once had a dash light blow out on me. I pmed you about that yellow wire. I found a whole dimmer/headlight/wiper arm assembly for $50. I just want to troubleshoot before it gets that far. 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted September 13, 2010 I Donated Share Posted September 13, 2010 Got your PM. Tomorrow after I get off of work I will take a picture of the wire I'm talking about. Its too dark now to get a good enough picture. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
skibob6 Posted September 14, 2010 Share Posted September 14, 2010 I had this problem with my legy. Check to make sure your running lights aren't out as well. I never solved this problem in my car but had concluded it was high resistance (like 20,000 ohms) on the ground wire (Stock stereo). When i took my car to the transmission shop and they couldnt do a TCM reflash they sent it to subaru; who I am assuming is who fixed it... Link to comment Share on other sites More sharing options...
frkkevin Posted September 14, 2010 Author Share Posted September 14, 2010 I had this problem with my legy. Check to make sure your running lights aren't out as well. I never solved this problem in my car but had concluded it was high resistance (like 20,000 ohms) on the ground wire (Stock stereo). When i took my car to the transmission shop and they couldnt do a TCM reflash they sent it to subaru; who I am assuming is who fixed it... Only time running lights work is when you turn the switch to the on position on top of the column. 512whp/465ftlb 2005 5EAT Legacy (Build Log) Videos - - Link to comment Share on other sites More sharing options...
jenders74 Posted September 15, 2010 Share Posted September 15, 2010 In the HVAC I wouldn't be surprised, both my legacys had them blown when I bought them. You might also have a bad dimmer switch. When I got my 97 all of my lights were blown. I went to Radioshack and Hobbytown USA to try and find them, but had no luck. Got them at the dealer for $10. Might not be a bad idea to try before spending the time and money on something else. Link to comment Share on other sites More sharing options...
skibob6 Posted September 18, 2010 Share Posted September 18, 2010 Only time running lights work is when you turn the switch to the on position on top of the column. Parking lights, running lights whatever. They stay on all the time if you push that switch. They come on before you turn your headlights on. its the second position on the light/dimmer. just to be clear. when my dash went out they were out too. Link to comment Share on other sites More sharing options...
