lucas569 Posted September 29, 2010 Share Posted September 29, 2010 I call BS... its possible on a lift. IF the subie tranny doesn't stick to the block it comes out very easy. NOW the EVO? thats a bitch to do! Link to comment Share on other sites More sharing options...
meier motor sports Posted September 29, 2010 Share Posted September 29, 2010 an hour in and out would be pretty damn quick Link to comment Share on other sites More sharing options...
GTLegacy05 Posted September 29, 2010 Author Share Posted September 29, 2010 an hour in and out would be pretty damn quick yea it was pretty quick like subarufanatic said our friend that did it knows what he is doing hes owned probably 4 subarus so far and has swapped out engines/trans many of times. Link to comment Share on other sites More sharing options...
GTLegacy05 Posted September 29, 2010 Author Share Posted September 29, 2010 hows the pedal? hows the engagement? when I first put it in pedal felt alittle differnet than stock, but now I cant even tell that I changed the clutch it feels almost like stock to me only difference is it pulls alot harder. engagement is really smooth also its not harsh at all you wouldnt be able to tell I have a stg 3 clutch in my car if you drove it. I would def recommend this clutch setup to anyone on a budget. Link to comment Share on other sites More sharing options...
Shainz Posted September 29, 2010 Share Posted September 29, 2010 Clutchmasters FX200 or FX300 get my vote. Link to comment Share on other sites More sharing options...
1astrokeit Posted September 29, 2010 Share Posted September 29, 2010 wut would u reccomend for daily driver stock but might go to stage 2 n possibly turbo upgrade down the road Link to comment Share on other sites More sharing options...
SSpeed Posted September 29, 2010 Share Posted September 29, 2010 I'm exactly that, was stage 2, putting on a BNR Evo3 16g... I went with the Southbend Stage 3 organic for the '06+ WRX on an ACT Streetlite flywheel... I love it... driveability of stock, no chatter, nice pedal feel, and most importantly holds power nicely.. Only thing is the Southbend is pretty expensive, in my opinion it's worth it though not to have the chatter... their stage 3 organic will hold 450 ft. lbs. supposedly and feels perfect on stage 2 power... Link to comment Share on other sites More sharing options...
1astrokeit Posted September 30, 2010 Share Posted September 30, 2010 i travel 30 miles one way for work and i hit stop and go traffic so i want a clutch that isnt to heavy on pedal side and engagement is smooth. Link to comment Share on other sites More sharing options...
croll326 Posted September 30, 2010 Share Posted September 30, 2010 I'm exactly that, was stage 2, putting on a BNR Evo3 16g... I went with the Southbend Stage 3 organic for the '06+ WRX on an ACT Streetlite flywheel... I love it... driveability of stock, no chatter, nice pedal feel, and most importantly holds power nicely.. Only thing is the Southbend is pretty expensive, in my opinion it's worth it though not to have the chatter... their stage 3 organic will hold 450 ft. lbs. supposedly and feels perfect on stage 2 power... So you purchased the "FJK1000 OFE series stage 3" clutch for an 04-08 WRX/STI? $575.00? Did you opt for the cryogenic freezing? Link to comment Share on other sites More sharing options...
Drew888 Posted September 30, 2010 Share Posted September 30, 2010 i travel 30 miles one way for work and i hit stop and go traffic so i want a clutch that isnt to heavy on pedal side and engagement is smooth. 45.5mi in LA traffic here so I need the same and to hold at least 400HP. Motor is being built as we speak and I need a decent clutch to hold it and not kill my leg. [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1586"VbGallery/URL] Link to comment Share on other sites More sharing options...
SSpeed Posted September 30, 2010 Share Posted September 30, 2010 So you purchased the "FJK1000 OFE series stage 3" clutch for an 04-08 WRX/STI? $575.00? Did you opt for the cryogenic freezing? FJK1001 for 06-09, you are seeing the STI clutch, you want the 06+ WRX. Yep $575, expensive but well worth it... Pedal feel was softer than stock at first, once it broke in it's exactly the same as stock.. engagement is very close off the floor, took a little getting used to but it's fine now.. if you've been driving a manual for a long time you'll have no trouble with it... I didn't do the cryogenic freezing.. http://www.dxdracingclutches.com/ ACT Streetlite flywheel is also fine, I wanted to do a Fidanza but they were too expensive. I've seen no drawbacks with that either, I think due to clutch selection. Link to comment Share on other sites More sharing options...
sleeper8406 Posted September 30, 2010 Share Posted September 30, 2010 Good thread Link to comment Share on other sites More sharing options...
lucas569 Posted October 2, 2010 Share Posted October 2, 2010 any input on the oem exady replacement? i just want a stock pedal feel, its like $60 cheaper than the oem wrx clutch. Link to comment Share on other sites More sharing options...
jaxx4k Posted December 18, 2010 Share Posted December 18, 2010 wondering if a softer pedal feel is better then ACT or Exedy... I like some what of a lower grab & stiffer feel.. how low does this CM grab?? Link to comment Share on other sites More sharing options...
